It will make it easier in the long run. You'll have to drill rivets out on the side bumper and enough on the belly pan on that side so that you can get into that area. Also remove the plate that has the ignition switch, choke lever and handwarmer switch and remove the small tool box. I've done them and they are not impossible but just takes time. Much easier and better access if chaincase, side bumper and belly pan have been removed.
