Just bought a 95 Polaris Indy 500 EFI - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 6 (permalink) Old 08-22-2012, 03:30 PM Thread Starter
FLASH1970's Avatar
This was my grandpas sled. He always joked around about putting remote start on it so I might do it for kicks. I was told it had a problem staying running when you tried to move but idled fine. So I got it home, checked fluids, started it up with starter fluid, then it'd die after 10 seconds. I disconnected the fuel line, no fuel coming out. So I hit it with some compressed air, freed up the fuel line, reconnected everything and it ran fine. I took around the yard. Then I had a problem for a couple minutes where it wouldn't go over 4k rpm. But I shut it down, restarted it and it ran ok again. I plan to replace the fuel filter and clean out the injectors among other things.
06 Fusion 900- HTG 975, HTG ceramic pipe & can, V Force 3's, gutted airbox, 136" Mountain Machines rail extensions, Fabcraft 8" wheels, SLP tunnel extension, 1.25 Ripsaw studded, left hand throttle added, Dual KOSO EGT's, Boondocker fuel controller, 2008 spindles, Boondocker Synergy kit, KOSO Wideband, 2" riser.
95 Indy 500 EFI- Ummmm, stock.
FLASH1970 is offline
post #2 of 6 (permalink) Old 08-22-2012, 03:38 PM Thread Starter
FLASH1970's Avatar
Here are some pics.
Name:	2012-08-11 12.01.03.jpg
ID:	19301   Click image for larger version
Name:	2012-08-11 11.58.54.jpg
ID:	19302   Click image for larger version
Name:	2012-08-11 11.56.39.jpg
ID:	19303   Click image for larger version
Name:	2012-08-11 11.59.39.jpg
ID:	19304   Click image for larger version
Name:	2012-08-11 11.56.26.jpg
post #3 of 6 (permalink) Old 08-22-2012, 05:00 PM
ride till your broke
Renagade's Avatar
nice sled!!!
i would check fuel pump pressure & compression.
does it rev past 4k on a stand? could be
a weak secondary spring? bad belt?
winters comming!!!!
current sleds
04 rev800ho gade
95 formulaIII 600
77 olympic 340e
Renagade is offline
post #4 of 6 (permalink) Old 08-22-2012, 05:36 PM Thread Starter
FLASH1970's Avatar
Not sure if it revs past 4k on a stand. After a couple minutes of sitting I started it back up and it was fine. The sled hadn't been run in 2 years and I think the newest trail sticker on it is from 02... So I'll go through it all.
post #5 of 6 (permalink) Old 08-22-2012, 07:17 PM
dhridenh's Avatar
my sled in my avitar looked the same as that sled its a 94 and mine is a sks but its a awsome sled u have the same problem with your top air filter that i had but i was able to fix the filter with out buying a new one i bot a shop vac air filter its the same stuff in the center then i removed both the rings from the filter cut the new media and then glued them together there a pic of it and look at my pics my girl thought your pic of your sled was my sled hahahaha
dhridenh is offline
post #6 of 6 (permalink) Old 08-22-2012, 07:19 PM
dhridenh's Avatar
http://www.snowmobileforum.com/gener...9-paint-2.html this is the paint i did on it to get ride of the color that was on it i think it looks good
dhridenh is offline
