1996 Ultra 680 compression? - Page 9 - Snowmobile Forum: Your #1 Snowmobile Forum
Old 01-28-2013, 07:39 PM   #161 (permalink)
dhridenh's Avatar
Yea the sled is tipped up in the front on cinder blocks now with green 50/50 mix coolent
Old 01-28-2013, 09:39 PM   #162 (permalink)
Mighty Quinn's Avatar
Your getting closer,but the finer stuff is still in play
Old 01-28-2013, 11:33 PM   #163 (permalink)
dhridenh's Avatar
the one thing i can not fine are exhaust donut gaskets
Old 01-28-2013, 11:37 PM   #164 (permalink)
dhridenh's Avatar
or extra springs
Old 01-29-2013, 04:59 AM   #165 (permalink)
Ya know... someone probably here has a box of extra stuff like this just sitting on there shelf ? You may have to see your Polaris dealer .
You could also check at some muffler shops & match up what you have ,you may luck out ? I have 1ex.doughnut to worry about ,you have 6 . Crapy they are missing !
Old 01-29-2013, 07:26 AM   #166 (permalink)
dhridenh's Avatar
I got 3 missing the other 3 are on the end of the exhaust hahahaha suck
Old 01-30-2013, 06:01 AM   #167 (permalink)
Some pics of the Ol' girl .
Old 01-30-2013, 07:52 AM   #168 (permalink)
Looks like brand new!!
Old 01-30-2013, 10:21 AM   #169 (permalink)
dhridenh's Avatar
Man that thing is a very clean Mq ECI have the aggressive Chessie though it's a little bit different But it looks very nice I have to say I can't wait to ride it and I got triple pipes you got single but it does look brand-new nice work
Old 01-30-2013, 07:25 PM   #170 (permalink)
Aahhh... thank you (RJ) & you to (dhridenh) . Took some work to get it back to where I like it looking like new again . Yup... your style of sled was the first Ultra to come with factory pipes ,the ULTRA SPX 135hp.
Although, with a little tinkering & a set of (Dyno Port) pipes & yes this thing can unleash the beast from 115 hp to a 150 -155hp ! For now... I 'll just leave it stock. A DG can would be nice to give it that triple sound that everybody will remember .
Old 01-30-2013, 08:06 PM   #171 (permalink)
dhridenh's Avatar
This summer I will get it a nice dg can for triples and rejet the carbs but for now I just want it running I work as a b level mechanic at a pep boys and I ordered up a new belt for it a dayco hpx 5013 for 44 bucks list was 131 and its on sale for 55 and my discount of 20% so good deal ooo came up with a good way to get the water/ ice out of the tank I got a wet vac and them put dry gas and deicer In it should work good for that
Old 01-30-2013, 09:44 PM   #172 (permalink)
joshkidner's Avatar
rejetting isnt necessary with changing the can as far as my knowlage knows. im about 98% sure its only when you change the pipes (expansion chambers)
Old 01-31-2013, 04:43 AM   #173 (permalink)
That's a awsome deal on the belt ,should of got two at that price.
If it was me with the tank ,i would take it off.Dump out what ever is in there into 5 gallon pail,or something.let the tank thaw out apply a little bit fuel then drain again.,But that's just me. I'ed be a little worried with the fumes & the shop vac .
Old 01-31-2013, 04:55 AM   #174 (permalink)
Yes... on the (DG) can & (Dyno Port) can exhaust, no need for jetting. The aftermarket pipes & silencer yes ... jetting ,clutching ,& maybe gearing for the type of riding.
Old 01-31-2013, 11:13 AM   #175 (permalink)
dhridenh's Avatar
Ok cool good to know now I just got the skis for this sled today I found out there camoplast skis can any one tell me how good they are they have a really nice keal on them And look to be in really good shape any one know anything About the skis
Old 02-01-2013, 01:05 AM   #176 (permalink)
Ahhh. the skis sound ok , but this thread sounds like it's almost to be hijacked from us all ,if you Know what I mean ? Not to be rude ,or anything
Old 02-01-2013, 07:24 PM   #177 (permalink)
OK... tomorow is the annual (Orlow poker rally) out at a little hall in the middle of nowhere ,about 17 miles from here,but I'm probably going to decide to head to the river again since it looks smooth like glass!
The terrain around here has a lot of snow ,but I think the rally will be a snow cross with the size of drifts out there, & after 65 miles I'll be picking peaces of myself off the snow .
Compression test is going to be done tomrrow & check plugs for burn .
Old 02-01-2013, 10:30 PM   #178 (permalink)
dhridenh's Avatar
so got the pipes on the sled checked the reed on mag side and the reeds were opened slightly so then i flipped the reeds over cleaned them reinstalled then put back on the sled started her up and now i lost pto side i will recheck compression again in that piston and re clean the carb i just dont get it man this thing is suck a pain in the a$$
Old 02-02-2013, 03:10 AM   #179 (permalink)
Ok... so you have the pipes & silencer (muffler) on the sled,good.
The reed issue in the MAG cyl. When a reed is bent ,or is showing a gap it is telling you that the material that it is made out of is starting to get fatiged , (breaking down).The reed pedals should't be turned over once they are arched,but be replaced .Think of a humming birds wings. At 8000 rpm those reed pedals open & close 7999 times,that's alot of work for those little suckers!Time for new replacement pedals.They could have a chance of breaking when you turn them over.
What do you meen you lost the PTO side? Did you loose spark ? Fouled plug? Check compression & see what you have,but it still should be at 125lbs.Let me know.
Old 02-02-2013, 07:04 PM   #180 (permalink)
Today was a good day.... I decided to hit the river instead of doing the rally man ...7 miles of the ruff, but after it was smooth as glass for at least 50 miles I made my own rally ,did a couple of stops . Camera kinda sucked alone the way ,but got some pics ,i'm glad I did it .It was so cool& the river of glass!
