location for delrin washer?
I bought one of these from SLP-at BC Dan's suggestion-for doing my driven clutch rebuild. The diagram from SLP shows two possible locations that the delrin washer can go depending on if I have a fixed or floating spring.
Sled is a 2004 RMK 700 and it has a TEAM driven clutch. I'm assuming it is a floating spring, since the spring I bought to replace the one that is already in the driven clutch, doesn't have any tabs on it. Am I right in my assumption??
