clutch roller bushings - Snowmobile Forum: Your #1 Snowmobile Forum
Old 07-26-2012, 11:13 AM   #1 (permalink)
dhridenh's Avatar
well today i was looking at my cluch and found that these metal round things were the weights on the cluch touch are completely worn out down to the pin under neath now are these things hard to change out i know i need to but i was going over the cluch to check the spring and weights and thats what i found not to happy need some help on this one guys
Old 07-26-2012, 02:24 PM   #2 (permalink)
To get the rollers out, you will need to disassemble the clutch. That will require some specialized tools. You will need a clutch holding fixture, a spider wrench, and a spider nut wrench. A clutch press is also nice. The spider nut and spider are really on there, you will need to re-torque those to over 200 ft.lbs. 1/2" drive tools need not apply. A good manual is also pretty important.
If this is the only clutch you are dealing with, it may be cheaper to have it rebuilt than do it yourself. Cost of rebuilding is sometimes almost the same as a new clutch, though!
Old 07-26-2012, 02:43 PM   #3 (permalink)
PolarisBlood's Avatar
Very true and Well said BC_Dan. New clutches (depending where you get them) can range from 250 and Up. You can EASILY spend that in just tool and parts.
Sometimes the spider and the nut are so fused together on the threads that you will never get them apart.
'97 Indy XLT limited - Sweet sled
'95 Indy XLT (my first Triple)
'91 Indy Classic - Stock - rebuilt clutch. - FOR SALE $600
'86 Indy 400 - Not Stock - FOR SALE - $800
'86 Polaris SS440 - FOR SALE $300 -
'86 Indy Trail - FOR SALE - $400 good beater sled!!!!
'85 Indy 400 - "WE WILL REBUILD IT!"
'79 Polaris Gemini 250 (244 Twin)
'78 Arctic Cat El Tigre 6000 (440 L/C)
'73 Polaris Colt 294S/S (F/A) - FOR SALE $300
PolarisBlood
PolarisBlood is offline   Reply With Quote
Old 07-26-2012, 03:29 PM   #4 (permalink)
white lightning's Avatar
Or you can have the dealer rebuild the clutch instead of buying the clutching tools to rebuild the clutch yourself. All youd be paying is for the parts cost and dealer labor to do the work. Just a thought. WL
Old 07-26-2012, 07:42 PM   #5 (permalink)
dhridenh's Avatar
hmmm i can get one on ebay for 150 i think for the money that i would spend fixing this one i can get one all set up and have this one rebuilt another day
Old 07-26-2012, 08:24 PM   #6 (permalink)
dhridenh's Avatar
Polaris Primary Drive Clutch PRO X 600 440 XC RMK 700 XCR Indy 500 | eBay
what do u think about this clutch u think the scratch will do anything to the performance
Old 07-26-2012, 10:34 PM   #7 (permalink)
I'd probably run it if it were mine, but I wouldn't buy it if it was yours... make sense? It's hard to tell what that will do the sides of the belt. I like my clutches as close to perfect as I can get 'em, they do a LOT of work in the drivetrain.
Old 07-26-2012, 10:56 PM   #8 (permalink)
dhridenh's Avatar
ok how about this one the clutch looks black from belts but what do u think of this one
95 96 polaris 600 indy XCR xlt primary drive clutch | eBay
Old 07-27-2012, 12:11 AM   #9 (permalink)
Make sure that the clutch your thinking of purchasing will work on your sled's engine. It's my understanding that the clutch for the Liberty engines will fit but you'll not be able to get them off.
Last edited by steepndeep; 07-27-2012 at 12:16 AM. Reason: didn't finish posting before I hit wrong button
Old 07-27-2012, 01:21 AM   #10 (permalink)
Seepndeep is right, they will fit. It's a 30mm taper on the end of the crank snout but he is wrong about the removal. you'll be able to get them off as they use the same thread on the bolt, but the bolt and hole in the clutch are a smaller diameter and that requires a different puller. But just to play it safe, if you (or a friend maybe even your dealer) has access to a Liberty engine that's been blown or had the clutch removed take a thread gauge and measure the thread of that bolt vs yours.
PolarisBlood
Old 07-27-2012, 09:47 AM   #11 (permalink)
I would also call the local dealers and see if they have any take-off clutches. Often, a sled doesn't come with electric start, and it is added at the dealer. The non-electric start clutches can't be modified to accept the ring gear, so a new clutch is part of the e-kit. The dealer ends up having a bunch of new or almost new clutches that they can't get rid of. I have seen them sell those for around 200 bucks, which is a really good deal.
It's worth a try!
Old 07-27-2012, 11:54 AM   #12 (permalink)
dhridenh's Avatar
ok so the clutch from the 600 is a liberty clutch is this because its a triple or somthing and i guess it will have to be from a sled that has the same clutch and your right it does look a little different
Old 07-27-2012, 02:25 PM   #13 (permalink)
Most Polaris snowmobile clutches are P-85 clutches. Most have a 1:10 taper on a 30mm shaft. Some of the newer ones have a 33mm shaft. Then there is a narrow roller and a wide roller clutch. Also, there are some of the Fuji engines that have a different offset in the clutch, so if you use a clutch with the wrong offset, it can wipe out your PTO crank seal. Polaris doesn't make it easy.
A good rule of thumb is any clutch for a Fuji twin will fit another Fuji twin, any clutch for a Fuji triple will fit another Fuji triple. Most Liberty (Polaris made) engines have the same crankshaft stub and offset, but different clutches will use different pullers. Then you get into the 33mm. Can't forget those! I haven't tried to put a clutch for a Fuji engine on a Liberty engine, so I'm not sure what will work and what wont.
Buying on Ebay is a crap shoot. If the clutch is coming off an identical sled, you should be good. But a lot of sellers don't know there are so many differences, so you may get a clutch that doesn't work for your sled. That is frustrating.
Old 07-27-2012, 04:52 PM   #14 (permalink)
dhridenh's Avatar
alright so i need to know if the starter ring gear be removed from the clutch
Old 07-27-2012, 07:11 PM   #15 (permalink)
dhridenh's Avatar
alright so the guy i am talking to about a clutch said the clutch can be used with out a starter and with out removal from the clutch its 150 with free shipping the guy said the rolers, weights and spring were in good shape and is very useable
thoughts Polaris Indy 500 prymary clutch with ring gear for electric start 1321736 | eBay
oo and if i do a blue spring what weight should i use like a 55g or somthing close the stock ones for it were 49.5 with a gold spring
Old 07-27-2012, 08:45 PM   #16 (permalink)
The ring gear works fine on a non e-start engine. Some guys even add one because it seems to help dampen vibration.
If the springs and weights in your clutch are fine, you can swap your stuff into the new clutch. When you take the cover off, note there is an X on the cover. There's a similar X on the spider. When you put the cover back on the clutch, make sure the X's are aligned.
Old 07-27-2012, 08:54 PM   #17 (permalink)
dhridenh's Avatar
yea i marked my old one to remove the spring so it should be good to go on it your bc dan u are the best bro
Old 07-27-2012, 09:00 PM   #18 (permalink)
dhridenh's Avatar
well i bot the new / used clutch hopefully we will be set from that
