Oil pump adjustment... - Snowmobile Forum: Your #1 Snowmobile Forum
Old 05-02-2012, 01:04 PM   #1 (permalink)
simy03
simy03's Avatar
I have a 2010 Polaris Rush. I recenlty had the pto side re-built due to engine failure. In talking to a guy that worked for polaris racing, he suggested that i turn my oil pump up, cause he said the 600 cleanfires are pretty lean. Does anyone know how I would go about that?
Sean Simonson
Past Sleds
'72 Cheetah
'73 Cheetah
'93 XCR 440
'94 XLT
'98 XC 600
'00 XCSP 500 SOLD 8/21/11
'06 Fusion 600 Sold 3/11/11
CURRENT SLED 2010 Polaris Rush 600 bought 11/25/11
simy03 is offline   Reply With Quote
Old 05-02-2012, 02:23 PM   #2 (permalink)
white lightning's Avatar
Just because he said that - get a 2nd opinion from someone else. Your dealer would be the best bet to ask ANYONE? WL
Old 05-02-2012, 07:21 PM   #3 (permalink)
Adjusting the oil pump is accomplished first by growing a third, reallly tiny hand on a double-jointed arm that can get under the air horns to get to the dang pump.
Barring that, Polaris makes a special tool that is bent in the right places to loosen the locking nuts and to turn the adjuster. I used a mirror to check all my IQ sleds to see if the marks align on the pump arm and the pump body. If they align, (all mine did) I left them alone. It's really difficult to get in there to change the adjustment. Some guys with the HO small block are removing the motor mount bolts and lifting the engine (with everything hooked up) to gain easier access to the adjuster.
Old 05-03-2012, 09:51 AM   #4 (permalink)
simy03
simy03's Avatar
The guy i talked to worked for Polaris Race program and not that I wanna "name drop" but worked on Levi Lavallee's race team, so I'm guessing he knows his stuff!!!
Sean Simonson
Past Sleds
'72 Cheetah
'73 Cheetah
'93 XCR 440
'94 XLT
'98 XC 600
Old 05-03-2012, 01:46 PM   #5 (permalink)
Do you have an idea what had happened to your RUSH? Why ur pto side needed rebuilt??
Old 05-03-2012, 03:03 PM   #6 (permalink)
all the new polaris sleds are super lean and very light on the oil for emissions.listen to the polaris guy and turn it up.
