suspension - Snowmobile Forum: Your #1 Snowmobile Forum
Old 04-29-2012, 05:34 PM   #1 (permalink)
suspension
do they make rebuild kits for a 1992 polaris indy 650 rxl sks front suspension
polaris_indy22 is offline   Reply With Quote
Old 05-01-2012, 02:44 PM   #2 (permalink)
stimpy's Avatar
If the shocks are black, then they are non-rebuildable, toss them and find some good used Fox shocks the same length, they can be rebuilt, fresh oil and charged for about 60 bucks. Or you can buy new Ride FX shocks or other aftermarket replacement shocks.
Without the proper tools and experience, I would not be cracking open a shock, the nitrogen is under a lot of pressure if it hasnt leaked all out, and can be dangerous.
Unless you are talking about the bushings and such in the front end, those can be bought at Dennis Kirk, Parts Unlimited, or even on eBay, if you are looking for a deal.
2000 Indy 500 XC, Fox shocks up front, M10 trail in back. '99 440 XCR for my son. 96 XCR 600 SP tripple pipe, 862 miles on it !! (until it snows....then look out, odometer !!)
stimpy is offline   Reply With Quote
Old 05-01-2012, 05:21 PM   #3 (permalink)
Terrain Dominator
JD8345RT's Avatar
I read in another thread that your sled has been sitting for 3 years? If the linkage is moving stiffly, grease it well first and see if that makes a difference.
1993 Polaris XLT Special
1972 Arctic Cat Panther
Old 05-01-2012, 05:25 PM   #4 (permalink)
One shock moves freely and the other is stiff so I'll try greasing it first then Ill go from there I'm trying to spend as little as possible because Im doing this on a small budget. Then If that doesnt eork ill try to find some fox shox
Old 05-01-2012, 07:03 PM   #5 (permalink)
I would pull the suspension and disassemble it completely to clean all the dead grease out of everything. That stuff can bind a suspension just like epoxy. The shocks shouldn't move too freely, that's the whole point of a shock; to dampen movement of the suspension.
Most early 90's suspensions are not worth spending a lot of money on. Disassemble/clean/reassemble and see how it works for you. Take lots of pictures as you go so when you get stumped you are not totally confused by the drawings provided.
If you have the funds for newer shocks, I would invest in an Xtra-10 suspension and swap that in instead. The suspension travel is a lot better in the Xtra-10, which will give you a much better ride. There is a lot of info regarding installing the Xtra-10 in older Indys, including measured drawings to help you with the swap.
Good luck on your project!
Old 05-01-2012, 10:13 PM   #6 (permalink)
for the shocks front and back could i just buy shocks that measure the same as the stock ones or do they have to be the exact shocks
Old 05-01-2012, 10:26 PM   #7 (permalink)
ride till your broke
Renagade's Avatar
measure from eye to eye on shock,
just get the same length.
current sleds
04 rev800ho gade
95 formulaIII 600
77 olympic 340e-mint!!
Old 05-01-2012, 10:28 PM   #8 (permalink)
stimpy's Avatar
as long as they are the same length, you should be good,they need to have the same travel as the stock ones.
Old 05-01-2012, 10:42 PM   #9 (permalink)
so lets say there 13 inches and i find a good deal on some fox shocks but they are for a quad i could use them?
Old 05-01-2012, 10:49 PM   #10 (permalink)
Renagade's Avatar
im not sure on that one??
but id figure as long as the stroke
is the same might work, but prolly
will have to revalve them??
never used quad shocks on sleds before,
let us know
current sleds
04 rev800ho gade
95 formulaIII 600
Old 05-01-2012, 11:16 PM   #11 (permalink)
That was an example I dont know if it would work or not
Old 05-02-2012, 05:21 AM   #12 (permalink)
stimpy's Avatar
quads are way lighter than sleds, I would say no, it would have weaker springs and be valved way too soft, plus no guarantee the shock eyes would be the right size or line up.
Old 05-08-2012, 08:11 PM   #13 (permalink)
xflyer53's Avatar
I have a good set in need of rebuild that will fit your sled. asking $40 for the pair. just the shox, no springs, you can use your current springs.
BTW, they are Fox
'92 Indy 650
'95 Indy XLT 600, plastic skis, skid plate, cobra windshield, XTRA 10, full Fox package, 1" riser
xflyer53 is offline   Reply With Quote
Old 05-08-2012, 08:22 PM   #14 (permalink)
xflyer53 could i get a picture of them
Old 05-09-2012, 08:22 PM   #15 (permalink)
xflyer53's Avatar
Fox Shox
Upper and lower spring retainers are next to them.
Should run between $30 & $40 each for rebuild.
Both have clean straight shafts.
'92 Indy 650
