Reverse kit - Snowmobile Forum: Your #1 Snowmobile Forum
Old 04-29-2012, 04:43 PM   #1 (permalink)
xflyer53's Avatar
Reverse kit
Will an evolved reverse kit fit into a wedge?
IE: 97 XLT into a 95 XLT
Thanks
'92 Indy 650
'95 Indy XLT 600, plastic skis, skid plate, cobra windshield, XTRA 10, full Fox package, 1" riser
xflyer53 is offline   Reply With Quote
Old 05-01-2012, 02:40 PM   #2 (permalink)
stimpy's Avatar
The drive train should be the same, quickest way is to pull up an online parts list, just google it, then compare the part numbers for each, I'm sure it will work, I was looking into reverse for my 96 XCR aggressive chassis, the XLT wedge touring revers chain case was the same part number for the base, the difference is the outer case, more room for the extra gears and shift linkage, but it all bolts up. I'm assuming yours will as well, but check the part numbers first.
2000 Indy 500 XC, Fox shocks up front, M10 trail in back. '99 440 XCR for my son. 96 XCR 600 SP tripple pipe, 862 miles on it !! (until it snows....then look out, odometer !!)
stimpy is offline   Reply With Quote
Old 05-01-2012, 03:22 PM   #3 (permalink)
Browse
Old 05-01-2012, 09:30 PM   #4 (permalink)
xflyer53's Avatar
inner case is the same part number from the 95 indy trail (wedge) as the 97 xlt touring (evolved). since they are the same, after swapping the inner case it should fit. thanks for ---> me in the right direction.
forum these days is kinda like this last winter, not much action....
'92 Indy 650
