Originally Posted by i_play_bass
Also meant to ask, was the Herculiner affected at all by the heat sinks below the running boards? I always see snow melting on the running boards after I've been riding a while... And did you prime/sand down the paint before spraying it down?
Thanks!
Those would be your heat exchangers under the runningboards melting the snow. Won't affect bedliner sprayed on the top side.
Don't strip the paint, bedliner is made to go on over it.
