Brake Light not working - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 10 (permalink) Old 02-17-2012, 11:16 AM Thread Starter
TRVLRS's Avatar
Question Brake Light not working
OK, I have read everything I can, but do not see a fix yet.
95 Indy XLT, all the lights were out, rep;aced the regulator now all work except the brale light, its a new buld works in the taillight position, but nothings working on the brake light, what else should I check?
TRVLRS is offline
post #2 of 10 (permalink) Old 02-17-2012, 01:40 PM
Snowweasel's Avatar
Test the brake light switch on the caliper
Snowweasel is offline
post #3 of 10 (permalink) Old 02-17-2012, 02:47 PM
rgoers's Avatar
Test the lamp in something else. I've seen lamps that look fine, but won't light.
2004 Polaris Trail RMK 136
1997 Ski Doo Summit 500
rgoers is offline
post #4 of 10 (permalink) Old 02-18-2012, 11:40 AM
ground?
Kariblay is offline
post #5 of 10 (permalink) Old 02-18-2012, 12:36 PM
Mpolly500's Avatar
I had a problem like that on a ski doo I never found out what the problem was but to fix it I tapped a wire to the dash lights an ran it to the brake light switch. It worked fine.
Mpolly500 is offline
post #6 of 10 (permalink) Old 02-18-2012, 01:05 PM
Break out the duct tape..
98yota's Avatar
Sounds like the stoplight switch if another power source turns on the light.
1980 Arctic Cat Panther 440 F/C
(2014 November Sled of the Month)
2011-2012 Mileage: 170
2012-2013 Mileage: 40
2013-2014 Mileage: 0
2014-2015 Mileage: 0
2015-2016 Mileage: 55
98yota is offline
post #7 of 10 (permalink) Old 02-19-2012, 11:08 AM
POL3INAROW's Avatar
Sound like the pressure switch failed. Check the orange wire at the caliper switch for hot when running, if it is hot, jump the two terminals together and see if the brake light comes on, if so, switch is cooked. If it does not light up with jumper then there is a problem in the loom under the seat or with the tail light wiring. If orange wire is not hot you can ck the loom for damage to the switch. An easy fix if it is not hot would be to cut the orange wire about two inches from switch connector and tap into the hot off of voltage regulator supply as it is close to the caliper switch, this should get you going again.
POL3INAROW is offline
post #8 of 10 (permalink) Old 02-20-2012, 08:25 AM Thread Starter
TRVLRS's Avatar
OK, Guys Thanks, I am sure I have enough info now, I thought there should be a switch somewhere, I am hoping I may just need to clean up the terminals on the switch, but we will see. I will post my fix when I know for sure.
Thanks again
Rick
TRVLRS is offline
post #9 of 10 (permalink) Old 02-20-2012, 06:19 PM
TRH- Troll Raising Hell
SMFXRSB's Avatar
Wires could have rubbed through under the seat. Harness could have came unplugged from under the seat. The bulb could be bad. There are two filaments for normal and bright light so change the bulb anyways. The switches do go bad and need terminals cleaned.
Snow: The other white drug!
SMFXRSB is offline
post #10 of 10 (permalink) Old 02-21-2012, 07:46 AM Thread Starter
TRVLRS's Avatar
It ended up being the connector on the caliper. cleaned them up and working great.
Never overlook the obvious!
TRVLRS is offline
