i'm 13 and need some help with a indy 500 efi! - Page 7 - Snowmobile Forum: Your #1 Snowmobile Forum
Old 02-08-2012, 08:53 PM   #121 (permalink)
The standard bore size for this engine is 2.8346" piston clearance should be around 0.004"
so a new piston with no wear should measure in at about 2.830" since you say your piston measures 2.827" it sounds like you have a standard bore there.
I wouldn't order parts until you resolve the bolt stuck in crank issue. If you can't get the bolt out you will have to pay restocking fees and maybe shipping for the parts you order and cannot use.
Also send us some pics of the bores , are they in good shape ? no scoring or scratches ?
how do they look around the port area. If they are damaged you may need to go oversize.
mrholmquist is offline   Reply With Quote
Old 02-09-2012, 06:11 AM   #122 (permalink)
the bolt is out! we ended up putting the bolt in the vise and turning the crank around it after heating it up... all the threads are fine, which is great!
thanks everyone!
ebben
epwhitehair is offline   Reply With Quote
Old 02-09-2012, 06:12 AM   #123 (permalink)
Originally Posted by Snowweasel View Post
I have a spare clutch to a Indy 500, (488) off a dead 1986 Polaris Indy trail. Ide let it got for 50 plus shipping.
Sent from my iPod
you have an email in your inbox...
thanks!
ebben
Old 02-09-2012, 06:31 AM   #124 (permalink)
Snowweasel's Avatar
Yeah, I got that. You should have a reply on ur email.
-Alex
Sent from my iPod
-my rides
1986 polaris indy trail (project)
1980 arctic cat jag 3000 F/A (looking to sell)
Snowweasel is offline   Reply With Quote
Old 02-09-2012, 09:45 AM   #125 (permalink)
-Alex
Sent from my iPod
hmmm... it didn't come through... any chance you could send it again?
thanks!
ebben
Old 02-09-2012, 10:42 AM   #126 (permalink)
Sconnie
jKsled's Avatar
glad to hear you got the bolt out!!!
1992 Polaris RXL 650 EFI
1990 Skidoo Formula MX 470
1997 Skidoo Grand Touring 500
1997 Arctic Cat Pantera 580
1979 Ford F150
~360 5.9L, Edelbrock intake, 4bbl carb, 4 speed, divorced transfer case, 3" body lift, 3" suspension lift, 33's, redone interior. Next up is stronger axles.
1981 Suzuki GS850L
Old 02-09-2012, 11:30 AM   #127 (permalink)
I don't know why I was thinking that this was a 650 not a 500.
Old 02-09-2012, 06:31 PM   #128 (permalink)
i found a set of used pistons... the old one says "5b" on the top, what does that mean?
thanks!
ebben
Old 02-09-2012, 06:38 PM   #129 (permalink)
scrammy650's Avatar
no decimal points that u can c maybe bored 50 thousands or .50
scrammy650 is offline   Reply With Quote
Old 02-09-2012, 06:40 PM   #130 (permalink)
nope, no decimals...
Old 02-09-2012, 06:51 PM   #131 (permalink)
scrammy650's Avatar
the only other thing i can think of is that its a s for standard bore not a 5 but not shure
Old 02-10-2012, 08:38 PM   #132 (permalink)
xflyer53's Avatar
What is the model # of the engine?
Guessing it is a EC50PL-07 based on the 5b that is on the piston.
That is a stock 72mm piston.
'92 Indy 650
'95 Indy XLT 600, plastic skis, skid plate, cobra windshield, XTRA 10, 1" riser
xflyer53 is offline   Reply With Quote
Old 02-10-2012, 09:10 PM   #133 (permalink)
RTC Performance
rickytmx313's Avatar
its behind the recoil and you'll need a puller to get it off
rickytmx313 is offline   Reply With Quote
Old 02-11-2012, 12:26 PM   #134 (permalink)
Red face Bent crank?
E's dad here.. I figured with all of the violence this main crank has endured I better do the best I can to measure for a bend before E sinks any money into this. I expected it to be off... and I hope we can live with this.
I flushed the bearings clean with kerosene and set the crank in the bottom pan. I then spun it while I mic'd the ends. The flywheel end is out .005". We are buying new main bearings for that end since they saw so much heat and sound questionable. Do you think with this amount of bend this motor will last him a few years or more or is this a ridiculous amount and we should abandon ship right now. I imagine the machine will rattle like an old school Harley... but hey... I have a harley that guys can't believe doesn't break my back! Let us know your thoughts. After all of this I hope we are not sunk.
J and E
Old 02-11-2012, 01:25 PM   #135 (permalink)
wastedincome's Avatar
I highly suggest get all new crank bearings and then checking the crank again.
02' XCSP 600 EDGE-X with M-10
wastedincome is offline   Reply With Quote
Old 02-11-2012, 02:00 PM   #136 (permalink)
all parts are ordered... including new crank bearing... should be here before tuesday! i'll post updates as we put it back together... right now we're just washing/greasing...
thanks everyone!
ebben
Old 02-11-2012, 02:20 PM   #137 (permalink)
thanks everyone!
ebben
Ebben, did u end up ordering crank bearings for just ONE side or ALL crank bearings ?!?!?!?
Old 02-11-2012, 05:43 PM   #138 (permalink)
2 bearings at the clutch end. The others seemed OK. Money can is empty!
Old 02-11-2012, 05:49 PM   #139 (permalink)
tisk, tisk, I'd rather donate $10 and see you do it RIGHT then only replace half the bearings as thats NOT proper.
Old 02-11-2012, 06:09 PM   #140 (permalink)
looking at parts it'll be another $150-$200 to put them in and have a machine shop press them... i just can't afford it.
it's all i could do to cover what needed to be covered, and the bearings seem as if they're in good shape....
thanks!
ebben
