Track too tight - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 21 (permalink) Old 01-20-2012, 05:15 PM Thread Starter
Track too tight
I just put a new track on my Ultra and it is way too tight. Tensioners haven't even been tightened yet. It is very hard to turn using the secondary and almost impossible by grabbing the track.
Everything is in good order in the chain case, both driveshaft bearings are good.
I had the skid out to put new hyfax on and greased it up. I did have the shocks off to check them too. The only thing I changed is the preload on the front track shock, it was all the way down and I turned it up to whee it should be for me.
Any thoughts?
Mike
1997 Polaris Ultra
1997 Polaris XLT Special
http://www.travelwisconsin.com/snow-...mobile#/Report
http://osceolavalleysnogoers.com/
10-11 miles: 425
11-12 miles: 362
12-13 miles: .7
mtwi is offline
post #2 of 21 (permalink) Old 01-20-2012, 05:54 PM
stimpy's Avatar
Is the rolling resistance too hard, or the track actually tight on the skid? if you push down lightley on the track on the bottom of the skid while it is propped up, you should be able to get a 1" or better gap. That would show tension is fine, this happened to a buddy and I when swapping a new 1.25 track on his RXL, could not turn it by hand, and it would barely move, smoking the belt if we tried too hard. Turned out my buddy had adjusted the chaincase tensioner with a wrench.... binding up the chaincase and making the drivetrain almost impossible to move. Backed it off, then turned it in finger tight to just put tension on chain case, and thats all it took, track turned fine, and it would lift the skis on take off. Double check for binding in the chain case, even if it means pulling the cover and draining lube.
2000 Indy 500 XC, Fox shocks up front, M10 trail in back. '99 440 XCR for my son. 96 XCR 600 SP tripple pipe, 862 miles on it !! (until it snows....then look out, odometer !!)
stimpy is offline
post #3 of 21 (permalink) Old 01-20-2012, 06:16 PM Thread Starter
Actually, it is both. Very hard to roll and very tight on the skid.
I can't get it to push down hardly at all.
I did also verify that it is the right track for the machine (121x15 2.52 pitch)
I will try the chain tension again, though it was just set properly.
I had a clearance issue between the track and tunnel protector strips, so I dropped the rear of the skid and removed the strips. It was just as hard to turn when it was contacting the strips as it is now that there is clearance.
Mike
1997 Polaris Ultra
10-11 miles: 425
11-12 miles: 362
12-13 miles: .7
mtwi is offline
post #4 of 21 (permalink) Old 01-24-2012, 12:11 AM
ClassicIndy600's Avatar
you removed your tunnel supports? did you replace the front a-arm in the skid or move skid hole locations on the tunnel?
ClassicIndy600 is offline
post #5 of 21 (permalink) Old 01-24-2012, 07:26 AM Thread Starter
For what it's worth, those strips do little if any to support the tunnel. They might add a fraction of rigidity.
I changed nothing in the skid, aside from the preload on the front shock, and it is bolted in the same spot it came out of.
I'll get back to it tonight or tomorrow, I have a van in the garage right now I am working on.
Mike
1997 Polaris Ultra
10-11 miles: 425
11-12 miles: 362
12-13 miles: .7
mtwi is offline
post #6 of 21 (permalink) Old 01-24-2012, 11:08 AM
rgoers's Avatar
It should hang a little on its own. You should be able to press it down and get 2-3 fingers between the track and the hyfax. If not - you need to loosen the track tensioners at the rear of the skid!
You want the track as LOOSE as you can get it, without it ratcheting on the drivers.
2004 Polaris Trail RMK 136
1997 Ski Doo Summit 500
rgoers is offline
post #7 of 21 (permalink) Old 01-24-2012, 11:29 AM Thread Starter
There is NO tension on the track. As a matter of fact, there is 1/2" between the end of the bolt and the block on the axle.
Mike
1997 Polaris Ultra
10-11 miles: 425
11-12 miles: 362
12-13 miles: .7
mtwi is offline
post #8 of 21 (permalink) Old 01-24-2012, 11:42 AM
Did you loosened the the rear axle bolts to adj. the tension?
If you did; than try shortening the front limiter strap.
mmgg is offline
post #9 of 21 (permalink) Old 01-25-2012, 11:32 AM
Just for yucks, make sure your cogs are "in" the track and not pressing against the inside of the track. You'd lose a good inch or so if they're not.
Make sure you have loosened the bolts on the rear wheels so the shaft can slide forward. You may have to use a rubber mallet to get them to go forward as they do tend to stick sometimes.
Also, make sure your tension bolts are backed out to allow it to move.
If it's the right track, it has to be one of these three things.
robhill1965 is offline
post #10 of 21 (permalink) Old 01-25-2012, 01:06 PM
Sounds like the rear axle is stuck. like others have said, make sure the axle bolts are loose and you may need to encourage it to move.
Good luck.
04 700 Classic w/ M-10
90 Indy 500, 11,XXX mi
rbrumm is offline
post #11 of 21 (permalink) Old 01-25-2012, 01:37 PM
rgoers's Avatar
I usually have to place a 2x4 against the track, and give it a few good whacks with a large rubber mallet.
rgoers is offline
post #12 of 21 (permalink) Old 01-25-2012, 02:05 PM Thread Starter
Good luck.
Good suggestions guys. I appreciate it. I will loosen the bolts next time I work on it. I believe the rear axle is all the way forward though.
Just for grins, someone want to check the track specs again for me? Camoplast part # 2602-002.
I realize this in an AC part number, shouldn't matter though as is the same specs as a track for my Polaris.
Mike
1997 Polaris Ultra
10-11 miles: 425
11-12 miles: 362
12-13 miles: .7
mtwi is offline
post #13 of 21 (permalink) Old 01-25-2012, 06:19 PM
69CRUZR's Avatar
the track will fit. make sure you dont have the rear shock arm that pivots and compresses with the suspension flipped too far past its travel point so that the skid doesnt compress and cycle properly. Ive done that. Just look where the lower shock bolt attaches, you will see the arm that moves around and make sure its sitting in there right, it can get flipped too far without even dissasembling it.
Also, you dropped your skid... I have a feeling thats where the problem is. You change lots of geometry by doing this, but was it in a factory supplied hole? Or did you make one?
1998 Polaris XC600 (with a XCR sleeper hood on it)
2006 Polaris Indy 500
1969 Chevy C10 "69CRUZR"
-383 stroker 450 hp 479 ft lbs of torque
2006 Chevy Colorado -daily driver
New Project Truck, this one for my Pops!
1953 GMC 5 Window Shortbox Stepside
Drivetrain: 2006 5.3 Liter v8 with 4l60e from an 06 Silverado.
Full IFS front suspension kit w/rack and pinion steering, and 4 link rear from TCI Enterprises.
69CRUZR is offline
post #14 of 21 (permalink) Old 01-25-2012, 07:12 PM Thread Starter
I will check it out. Anything is possible at this point.
Sorry for the confusion, I dropped it, meaning I took it out.
It is in the stock location, there are no extra holes for the xtra-12.
One the van gets out of the way (day 3 waiting for parts.....................) I will tear into it again.
Mike
1997 Polaris Ultra
10-11 miles: 425
11-12 miles: 362
12-13 miles: .7
mtwi is offline
post #15 of 21 (permalink) Old 01-26-2012, 12:00 PM
To get around the "geometry issue", I always take the spring off it's forward slide point on both sides of the sled. You'll have to tip it over for the spring to swing down and back out of the way. That relieves the tension and makes it much easier to take off and put back on. It allows the top rear of the track (where the rear shock mounts) to drop down. You should be able to rotate your track like this now to make sure it's seated where it's supposed to be (aligned and onto your front cog). Once you're sure it's on correctly, tip you sled over on each side again and put the springs back. Again, make sure your rear axle is all the way forward and the bolts are loose.
post #16 of 21 (permalink) Old 01-26-2012, 01:16 PM
rgoers's Avatar
I use the same trick (take springs off front slide points) but instead of having to tip the sled back and forth, I lift the rear off the ground about a foot. That makes it easy to swing the springs around. It's also easy to get the skid in and out that way. I put a floor jack under it, and use the jack to roll it and raise it into place.
rgoers is offline
post #17 of 21 (permalink) Old 01-26-2012, 01:38 PM
Yeah, I can't jack mine up high enough so i just tip it over. It's also easier to use gravity and drop the skid down into the track than have to wrestle it up, over, and into.
post #18 of 21 (permalink) Old 01-26-2012, 05:38 PM Thread Starter
Here are a few pics how it sits now.
Finally got the part I need to fix the vehicle in the garage and will look at the sled later tonight or tomorrow night.
Mike
1997 Polaris Ultra
10-11 miles: 425
11-12 miles: 362
12-13 miles: .7
mtwi is offline
post #19 of 21 (permalink) Old 01-27-2012, 06:06 PM Thread Starter
Update:
I am a moron..................
Got the garage cleared last night, moved the sled over and loosened the rear axle(wheel) bolts a little more. Guess what, there is slack in the track. LOTS of slack.
I figured the rear axle was all the way forward already, so it never dawned on me to check the bolts again. Figured I messed something else up when the skid was out.
Thanks to all who helped with this
Mike
1997 Polaris Ultra
10-11 miles: 425
11-12 miles: 362
12-13 miles: .7
mtwi is offline
post #20 of 21 (permalink) Old 01-27-2012, 06:26 PM
wastedincome's Avatar
Update:
LOL, I think we have ALL had moments such as yours....Glad u got it all sorted out
02' XCSP 600 EDGE-X with M-10
wastedincome is offline
