voltage regulator? - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 7 (permalink) Old 10-28-2011, 01:44 PM Thread Starter
voltage regulator?
I have a 1995 polaris indy 440.The headlights,taillights,dash and handwarmers do not work. would changing the voltage regulator fix my problem?
Todouble is offline
post #2 of 7 (permalink) Old 10-28-2011, 03:33 PM
RXL
Fool Injected
RXL's Avatar
If the bulbs are all burnt then yes .. if not it's a wiring issue.
RXL is offline
post #3 of 7 (permalink) Old 10-28-2011, 03:52 PM
aduck's Avatar
Quoted: 13 Post(s)
check the reading coming out of the regulator
93 mach1 670
02 rmk 800 162
95 powder special 580
aduck is offline
post #4 of 7 (permalink) Old 10-28-2011, 04:04 PM Thread Starter
@rxl all the bulbs are burnt. the headlight in the middle is burnt but the two on the sides seem to b ok.
@aduck what should the reading be?
Todouble is offline
post #5 of 7 (permalink) Old 10-28-2011, 05:15 PM
About 12vac at idle and up to 28vac at 1/3 throttle.
post #6 of 7 (permalink) Old 10-29-2011, 10:31 AM
If the voltage regulator has gone out, which it sounds like it has, the hand warmer elements may also be fried if switch was left on.
ntwizard is offline
post #7 of 7 (permalink) Old 11-02-2011, 01:45 PM Thread Starter
so i replaced the voltage reulator and got the tail lights to work but nothing else. I did find a split wire on the wire harness right by the front bottom of engine by the cooling hoses . the wire just loopes from one side to the other on the wire harness. can i just replace that wire or do you have to replace the whole harness?
Todouble is offline
