Snowmobile wont start! HELP? - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 3 (permalink) Old 03-16-2011, 05:01 PM Thread Starter
got the sled for a steal cause it wasnt running right, found the problem the carbs were literally frozen, so i emptied out every line in every part of the sled and put fresh gas, put it all back together wont start, engines flooding the crankcase is full of gas, it has some spark
i emptied everything out put a bit of gas in the cylinder, and it turns over only a little like 1 tiny fire and its done, any suggestions?
sled is a 2000 polaris triumph (basicly xlt motor) 120-125 psi across
leclairb is offline
post #2 of 3 (permalink) Old 03-16-2011, 05:38 PM
The engine will flood (fill up with gas) if the fuel pump diaphragm is ruptured (rebuild pump) or a needle isn't sealing, which required replacing needle/seat seat.
Once the leak is found and repaired, and crankcase is drained of gas, it should start, though it might require you to pull it over as if its flooded.
bob
bob15 is offline
post #3 of 3 (permalink) Old 03-16-2011, 09:49 PM
Trevor
YamahaSS440's Avatar
That has the rack style carbs correct?
2009/2010 Miles:900
2010/2011 Miles:1300
2011/2012 Miles:530
2012/2013 Miles:1050
YamahaSS440 is offline
