Need help No lights - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 8 (permalink) Old 02-08-2011, 08:34 PM Thread Starter
Need help No lights
Sled runs great but there is no head light no tail light no dash light . Do you know what it could be. Thanks 1998 Polaris XLT SP. Everything was working.
4U2RACE is offline
post #2 of 8 (permalink) Old 02-09-2011, 09:38 AM
check to see if there is anything shorting out, i had the same problem with my 01 xcsp and it ended up being the connector for the heated visor, or it could be the voltage regulator
2001xcsp is offline
post #3 of 8 (permalink) Old 02-09-2011, 10:31 AM
98 polaris RMK 700
jimmybo1979's Avatar
I would also say voltage regulator. I had the same problum. Its right behind the key panel. When the led is running it will glow orange.
jimmybo1979 is offline
post #4 of 8 (permalink) Old 02-09-2011, 11:11 AM
Check the wiring harness connection that goes under your seat to the rear light. Could have become lose, and will cause your problem. Just use a light tester and see if you have any power to the wires that come off the engine. If you do, check to see if you have any power to the ones on the other side of the connector, if you don't then you have found your problem.
Leeworthy is offline
post #5 of 8 (permalink) Old 02-09-2011, 04:33 PM
GearHd6's Avatar
X2,
Voltage Regulator probably went bad and blew all your lights out. Pull some bulbs and verify they are/aren't blown.
1998 Polaris XLT Limited (FAST M-10)
GearHd6 is offline
post #6 of 8 (permalink) Old 02-09-2011, 04:44 PM
Originally Posted by GearHd6 View Post
X2,
If you replace the bulbs, don't rev the engine when you start it. Revving the engine will just fry your new lightbulbs. Just let it idle and see if the new bulbs light. If not, pull the yellow wire off the regulator and check for lights. Although they're a little pricey, get an OEM regulator. Aftermarket ones are junk and Polaris has superseded the original with one that is much better quality. Check Polarisman.com.
Skid is offline
post #7 of 8 (permalink) Old 02-09-2011, 04:54 PM
guitarman69's Avatar
I would also say its your regulator. Been there too many times.
Good luck
Ride, Wreck and Repair
guitarman69 is offline
post #8 of 8 (permalink) Old 02-09-2011, 06:01 PM
GearHd6's Avatar
Yeah definitely don't start the sled if the bulbs are blown. I just wanted him to verify whether they're blown or not. If they're blown then it's the regulator, if they aren't blown then you'll have to look elsewhere for problems.
And yes, the new Polaris regulators are much better quality but tricky to mount on some applications.
GearHd6 is offline
