Carb boots. - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 11 (permalink) Old 02-02-2011, 08:25 PM Thread Starter
Polaris 1st's Avatar
Carb boots.
New to the site and a new owner of a 97' XLT SP.Sled has just under 3k miles and is in good,stock condition.I am hearing stories about bad carb boots being the death of engines.Is there a process of troubleshooting these or maintenance I can do to insure there in good cond.? Thanks in advance guys.BTW I have owned sleds in the past but just getting back into it so I just need a little bit of help on the newer maintenance.Thanks again for any help.
Polaris 1st is offline
post #2 of 11 (permalink) Old 02-02-2011, 08:32 PM
Long Live Triples!
SledHead454's Avatar
spray carb cleaner around them, if there is an rpm change, they need to be replaced
1998 Polaris XLT 600 Special
IQ Seat and Tank
144" Track and Tunnel Extension
SLP Silencer, 3" Handlebar Risers
Camoplast Plastic Ski's
42/34 Helix, Blue/Silver Secondary 3rd Hole
Long Live The Triples
SledHead454 is offline
post #3 of 11 (permalink) Old 02-02-2011, 09:01 PM
ZR rider
TwinsofMLB's Avatar
Starting fluid will give a bit more noticeable difference. If they're cracked, it's better to replace them than it is to check them and feel safe knowing it's not all the way through yet. If they happen to break when you're out on the trails you'll either ruin the engine or need a tow out to avoid ruining the engine.
TwinsofMLB is offline
post #4 of 11 (permalink) Old 02-02-2011, 09:56 PM
baldy68's Avatar
A less messy way is to use a propane blow torch plus with the long end you can get under the boot as well. Turn it on but don't light it, start your sled and pass the end around the boots. You should hear a difference if the boots are bad.
91' Polaris Indy 500 SP
01' Polaris 600 XC SP VES w/SLP silencer
93' Kawasaki Vulcan 750 customized
01' Kawasaki Vulcan 750 in the works
87' GMC 3500 crew cab "Clifford"
baldy68 is offline
post #5 of 11 (permalink) Old 02-02-2011, 11:11 PM
Yep...that's the best way to check them, just don't light the torch... but for cheap insurance, just buy new ones if there is any deterioration or cracking. They're not that expensive and not hard to change.
Skid is offline
post #6 of 11 (permalink) Old 02-03-2011, 07:05 PM Thread Starter
Thanks for all the input guys,I like the propane idea.I knew as soon as I purchased a sled I would appreciate this site.
post #7 of 11 (permalink) Old 02-03-2011, 07:09 PM
brandcole73's Avatar
Yep, do it before it ends up like mine. Blew it up from a crack on the bottom of a carb boot that couldn't be seen by just looking/poking at them.
brandcole73 is offline
post #8 of 11 (permalink) Old 02-04-2011, 08:33 PM
ZR rider
TwinsofMLB's Avatar
My thoughts exactly!
post #9 of 11 (permalink) Old 02-05-2011, 05:57 PM
What are the symptoms of boots going bad? Anything noticeable while running? Thanks
Blake
99 Polaris Indy 500 Classic Touring. Grew up riding 760 Panther, 399 Cheetah, and early Rupp 340.
Blakers is offline
post #10 of 11 (permalink) Old 02-05-2011, 07:20 PM
ZR rider
TwinsofMLB's Avatar
Well if you have an air leak, it'll run lean.
post #11 of 11 (permalink) Old 02-06-2011, 07:01 PM
I just changed the ones on my 97 xlt special.Got mine from Dennis Kirk.
Alot cheaper than genuine Polaris,and there made by Mikuni.I think they were $16 each,thats i think less than half of genuine Polaris.They are slightly shorter in length and that means that on the side that has the engine movement stop "snubber",there is a little interferance with the carb bowl
on the clutch side carb,but its nothin a grinder cant take care of.Actually i used a metal file,thats how little work you have to do.
Just change them anyway,its cheap insurance
600 XLT
600 xlt is offline
