1996 xlt wont start without pouring gas in cylinder - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 6 (permalink) Old 02-01-2011, 06:31 PM Thread Starter
New this season... pulled the carbs, and cleaned them. Anyway, the sled won't start unless I pour sowme gas down each of the cylinders. Once I put gas down the cylinders she fires right up and runs great after a few seconds. What's going on? Needs more vacuum to pull gas to the crabs? Any suggestions? Thanks.
zeus87 is offline
post #2 of 6 (permalink) Old 02-01-2011, 07:00 PM
maybe the gaz pump or the float needle in the carb or bad compression
dadavid is offline
post #3 of 6 (permalink) Old 02-01-2011, 07:58 PM
check your fuel lines. if you have a crack or loose connections it will make it impossible for the pump to supply the carbs.
Polaristaz is offline
post #4 of 6 (permalink) Old 02-01-2011, 08:21 PM
ZR rider
TwinsofMLB's Avatar
Just clean the carbs. 96 xlt... that has a choke, right? It's probably not working correctly because of that crappy ethanol buildup.
TwinsofMLB is offline
post #5 of 6 (permalink) Old 02-01-2011, 08:45 PM
Need Snow!!!!!
Brummo's Avatar
Check your pick-up tube in the tank. I had that problem.
http://www.iowa-snowdrifters.org/
'10 Polaris Rush 600
3450 miles, Studboy Deuce Carbides
'04 700 Classic 7350 miles
M-10 suspension, Boyesen Reeds
Stud Boy Deuce Carbides
Brummo is offline
post #6 of 6 (permalink) Old 02-02-2011, 05:59 AM
Does it stay running after you prime the cylinders? If so, you probably just need to clean and adjust your choke circuit properly. It isn't too hard to do, good luck.
2003 Yamaha RX-1 1000
2000 Polaris 700 XC 45th Anniversary Edition
1997 Polaris Indy 500 Sport
1998 Polaris Indy 500
1996 A Cat panther dlx 440
kikkinurazz3 is offline
