heated face shield plug - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 9 (permalink) Old 01-28-2011, 02:12 PM Thread Starter
i wanna put a heated face shield plug on my sled but there is no battery. So my question is where would i wire the plug into?
1996 polaris XLT 600 triple
model # 0966756
cgregory is offline
post #2 of 9 (permalink) Old 01-28-2011, 02:26 PM
Could you possibly wire to the heated hand warmers or thumb warmer harness? I would assume that the voltage would be regulated to them and run around the same that is needed for the shield plug?
Leeworthy is offline
post #3 of 9 (permalink) Old 01-28-2011, 02:37 PM
brandcole73's Avatar
Most if not all electric shields work on AC power. (disclaimer, don't hold me responsible if I'm wrong!) Just hook it to any AC in your sled. I just hooked mine up last night, had an extra plug on my MXZ that had power right by the oil tank. No battery in mine either. I tested it with a multimeter on AC when the sled was running. Works great! you'll probably never go back to a non heated.
brandcole73 is offline
post #4 of 9 (permalink) Old 01-28-2011, 08:03 PM
08 600HO Switchback
shags's Avatar
On my 08 switchback it was DC power. My understanding is they work both ways, I tapped into the accessory plug.
shags is offline
post #5 of 9 (permalink) Old 01-28-2011, 08:18 PM
2001 Polaris Edge X 600
On the EDGE 600's Avatar
Wire into the hand warmers
if you pull the pad off the handle bars and cut into and sauder the wires for your shield to your hand warmers it works perfect that's what I did and i've nerver had a problem.
On the EDGE 600 is offline
post #6 of 9 (permalink) Old 01-29-2011, 11:00 PM
jrscars's Avatar
on most all polaris sleds the yellow wire (anywhere you find a yellow) is a 12 volt power wire, you will find yellow going to lights, and hot grips
98 Polaris XC600 (M10 suspension, Boyesen reeds, SLP clutch kit, SLP can)
95 Jag 440 (daughters sled)
"Speed is expensive, How fast do you want to go?"
"You must be fast, cause when I passed you I was Haulin @$$!"
jrscars is offline
post #7 of 9 (permalink) Old 02-01-2011, 05:33 PM
i to got a heated shield, the rca cable has to rings to connect to battery, no battery so just splice into the 2 wires goin to the hand warmers?
indy700 is offline
post #8 of 9 (permalink) Old 02-01-2011, 06:44 PM
also whats the best way with no sodering gun
indy700 is offline
post #9 of 9 (permalink) Old 02-02-2011, 05:46 AM
You should tie into the hand warmers under the handlebar pad. Make sure you use a test light to find +/- and if your not going to sauder I would probably cut the wires strip them off, get some shrink tubeing and twist your wires together as tight as possible and them shrink tube them but if you can sauder it I would recommend it.
