'96 Indy Hood Repair - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 6 (permalink) Old 12-09-2010, 11:30 PM Thread Starter
I have a 1996 Polaris Transport that I purchased with a damaged hood. I've tried repairing the cracks with fiberglass from the back side of the hood but the resin doesn't dry between the plastic hood and the fiberglass mesh. The side exposed to the air dries but the other side stays sticky. Is there anything I can use to repair my hood? Thanks.
kvanoort is offline
post #2 of 6 (permalink) Old 12-10-2010, 12:40 AM
I just fix 'em...
IRONDOG's Avatar
That hood is the same as almost every Indy hood from 1988 to 1994 and some models used it through 1998. I would find a used hood rather than repairing that one.
Jerry
www.snowmobileswapmeet.com
IRONDOG is offline
post #3 of 6 (permalink) Old 12-10-2010, 02:22 AM
Hank Scorpio
STROMVADER's Avatar
Welcome to the forum! I had the same issue at first. Get all the sticky goo off and mix up another batch of resin, but use a generous amount of hardening liquid so it dries fast (5 drops). As I'm mixing the resin, the resin is already starting to harden. That should give you an idea of how much hardener I use. I also apply the resin with a throw away brush. Another important factor is the ambient temperature of your workspace. The resin likes a warmer environment. As always, make sure the repair area is clean and free of debris. Hope this helps!
1999 XC700, dual carbides, 1.25" Predator with 96 picks, AKA Lady Liberty
1990 Indy 400, picks, custom tail section, moto bars, Fox shocks, snow camo'd, AKA Camosled
PRAY FOR SNOW!!!
STROMVADER is offline
post #4 of 6 (permalink) Old 12-10-2010, 07:23 AM
jrscars's Avatar
fiberglass doesnt stick to the plastic composite hoods, it will peel off in time, the best fix I have found is a 2 part epoxy you can buy at wal-mart, hardware stores, or most any auto parts store called "plastic Welder" as mentioned its a a 2 part epoxy that dries to a light cream color.
To repair the crack, drill a small hole at the end of the crack (stops the crack from running any further) V out the crack line with a dremel tool, then fill back in with plastic welder epoxy, cures in half an hour, can be sanded and painted. This stuff is best i have found, I have fixed many hoods with it, in fact I have a spare hood I am working right now I am going to fix and put on my sled.
98 Polaris XC600 (M10 suspension, Boyesen reeds, SLP clutch kit, SLP can)
95 Jag 440 (daughters sled)
"Speed is expensive, How fast do you want to go?"
"You must be fast, cause when I passed you I was Haulin @$$!"
jrscars is offline
post #5 of 6 (permalink) Old 12-10-2010, 08:09 PM
Need Snow!!!!!
Brummo's Avatar
I repaired mine with fiberglass, and it woked great. I did scuff up the area before to, to give it something to bond to easier..
http://www.iowa-snowdrifters.org/
'10 Polaris Rush 600
3450 miles, Studboy Deuce Carbides
'04 700 Classic 7350 miles
M-10 suspension, Boyesen Reeds
Stud Boy Deuce Carbides
Brummo is offline
post #6 of 6 (permalink) Old 12-11-2010, 07:50 AM
carvinmark's Avatar
I agree that this is the best way to repair it. After 25 years in the auto body repair business, I have done several sled hoods.
2000 Ski Doo Touring
Lots of chainsaws
Sandrail, Corvair powered
63 Falcon
carvinmark is offline
