oil tank removal - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 8 (permalink) Old 10-26-2010, 04:58 PM Thread Starter
oil tank removal
My 2002 Indy Trail Touring (550 cc) is leaking 50:1 oil from the fitting at the bottom of the oil tank .
What is the best way to remove the tank (do I need to disconnect the muffler) and is there a way to tighten up the fitting at the bottom of the tank so that it doesn't leak or does something need to be replaced. Thx much!
milist is offline
post #2 of 8 (permalink) Old 10-26-2010, 06:54 PM
BAHNN Motorsports
there is a rubber grommet on the bottom of the oil tank which is suppose to seal the outgoing oil line and sometimes they come loose. First, I'd check the grommet to make sure it's not crimped in any way. REMOVAL: the line goes from tank to the oil pump will have to be disconnected and a bolt on top behind the oil level sensor & cap and a screw which holds the tank into the bracket on the left side as you sit on the sled.
Quality used OEM Polaris snowmobile replacement parts bahnnmotorsports@gmail.com
Bahnn120 is offline
post #3 of 8 (permalink) Old 11-01-2010, 11:52 PM
I ride, therefore I am...
Kilroy's Avatar
let me know if you didn't get this done yet and have questions. I serviced my wife's RMK 700 today and found a puddle of oil on the garage floor. I just ordered the grommet and new filter online. After removal I noticed that it's a pretty cheap setup that needs replaced when it starts leaking. I thought the oil was coming from the chain case.
One thing to note is that you will probably have to remove the coils, and air box to get to a small screw that sets the tank from moving side to side. I can take pictures and post if you are having problems. Be sure to use a turkey baster and get all of the oil out. You can also remove the oil hose down on the pump like Bahnn suggested (you will have to anyway) and let is drain out into a pan. It's messy...
Let me know if you need some pic's. My tank is on the workbench as I type...
Kilroy
'07 700RMK Dragon 155
'07 600 HO RMK 155 (Mrs. Kilroy)
'04 700RMK Vertical Edge 144" (Jr. Kilroy)
No bastard ever won a war by dying for his country. He won it by making the other poor dumb bastard die for his country. " ~ George S. Patton
Kilroy is offline
post #4 of 8 (permalink) Old 11-02-2010, 12:08 AM
Sconnie
jKsled's Avatar
tip: (if it helps in your guys case) gas and oil lines can be effectively plugged with a golf tee. i keep two or three in each sled and the toolbox for anytime i have to mess with the lines!!!
1992 Polaris RXL 650 EFI
1990 Skidoo Formula MX 470
1997 Skidoo Grand Touring 500
1997 Arctic Cat Pantera 580
1979 Ford F150
~360 5.9L, Edelbrock intake, 4bbl carb, 4 speed, divorced transfer case, 3" body lift, 3" suspension lift, 33's, redone interior.
2003 Dodge 3500 srw 6spd
1981 Suzuki GS850L
jKsled is offline
post #5 of 8 (permalink) Old 11-04-2010, 06:56 PM Thread Starter
oil tank removal
Kilroy, I sent you a private message. Pics might help. Still trying to figure out what to remove and how to get to the bolt at the bottom of the oil tank.
milist is offline
post #6 of 8 (permalink) Old 11-05-2010, 12:07 AM
Kilroy's Avatar
I'll post some pic's in the AM when I get some shut-eye!
Kilroy
Kilroy is offline
post #7 of 8 (permalink) Old 11-05-2010, 12:13 AM
Kilroy's Avatar
I was incorrect. I see that your oil tank is located/joined with your airbox. I feel badly for misleading you.
I believe what you need is item #16 at the bottom of the tank:
SKU: 7052305
GROMMET-OIL SENDER 1 $2.97
Confirm that this picture is what your tank/airbox looks like???
Kilroy is offline
post #8 of 8 (permalink) Old 11-13-2010, 02:00 PM
Jay C
JayC's Avatar
Hey Guys, I have to replace my oil sender grommet as well...I removed the handlebar cover, seat and gas tank and had access to the bottom of the oil tank and grommet very easily. Took me 5 minutes. Just my $.02
Our Families' Sleds:
2008 Ski-doo MXZ Adrenaline 800r
2006 Polaris Fusion 600 HO
2000 Ski-doo Grand Touring 600
1981 Ski-doo Citation 3500
JayC is offline
