What is the difference between a VES and Non VES engine/ - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 20 (permalink) Old 10-11-2010, 11:29 AM Thread Starter
ped917's Avatar
Got a 01 RMK 800 snow check, was curious what the difference is between and VES and Non VES engine? and how do I know what I have?
ped917 is offline
post #2 of 20 (permalink) Old 10-11-2010, 02:22 PM
Variable Exhaust System .... power valves im pretty sure
2001polarisxcsp is offline
post #3 of 20 (permalink) Old 10-11-2010, 06:05 PM
69CRUZR's Avatar
yes it meants variable exhaust valve. your 01 SHOULD have them I believe. They are two circular black valves on each clinder towards the top. post a pic
1998 Polaris XC600 (with a XCR sleeper hood on it)
2006 Polaris Indy 500
1969 Chevy C10 "69CRUZR"
-383 stroker 450 hp 479 ft lbs of torque
2006 Chevy Colorado -daily driver
New Project Truck, this one for my Pops!
1953 GMC 5 Window Shortbox Stepside
Drivetrain: 2006 5.3 Liter v8 with 4l60e from an 06 Silverado.
Full IFS front suspension kit w/rack and pinion steering, and 4 link rear from TCI Enterprises.
69CRUZR is offline
post #4 of 20 (permalink) Old 10-11-2010, 09:13 PM
98700xc's Avatar
A 01 RMK 800 is a NON VES, the polaris 800's didn't get exhaust valves until 02.
98700xc is offline
post #5 of 20 (permalink) Old 10-12-2010, 07:44 AM Thread Starter
ped917's Avatar
is that a good or bad thing? I have been reading alot about the crank issues with this motor. From what I have gotten out of it, the non VES engines are alot better?
ped917 is offline
post #6 of 20 (permalink) Old 10-13-2010, 02:48 PM
stimpy's Avatar
the motors must be almost identical,I have a 2000 500 xc, and it has the castings for VES on the jugs, like it was made for it, but never milled out, and my son has a 99 440 xcr with VES,motors look identical to me, the exhaust manifold looks a little different, but thats all i can see.
2000 Indy 500 XC, Fox shocks up front, M10 trail in back. '99 440 XCR for my son. 96 XCR 600 SP tripple pipe, 862 miles on it !! (until it snows....then look out, odometer !!)
stimpy is offline
post #7 of 20 (permalink) Old 10-13-2010, 02:50 PM
hawkster's Avatar
i think only the libertys have ves too, no fujis with it
hawkster is offline
post #8 of 20 (permalink) Old 10-13-2010, 03:23 PM
Quoted: 102 Post(s)
The early Liberty engines did not have VES. But the 98 440XCR did have it. The 2000 600 Edge was next, then 2002 for the 700 and 800. Not sure when the 500 got it, I know the 2006 has it.
An engine designer can port a cylinder to make good power at lower RPM, or good power at high RPM. Porting in the cylinders can't work both ways. So, the Variable Exhaust closes the port for good low end performance, but the guillotine valve moves out of the way with engine compression so that the port can open up for good high end performance. Without the VES, porting is a compromise between low and high RPM performance. So, an engine equipped with VES (or other variable exhaust) should have a bit more power than one without.
BC_Dan is offline
post #9 of 20 (permalink) Old 10-13-2010, 04:29 PM
hawkster's Avatar
winter 2000-01 for the 700 with ves Snowtech Magazine - Snowmobiles, Snowmobiling, Snowmobile Techncial Data
600 xc had ves for 2000
2000 xc sp 500 had ves
hawkster is offline
post #10 of 20 (permalink) Old 10-13-2010, 05:50 PM
Quoted: 102 Post(s)
Interesting. That link also talked about triples with VES, I looked at the Polaris website, and the 700 and 800 XCR triples also had VES in 1999. Who'd of thunk it
BC_Dan is offline
post #11 of 20 (permalink) Old 10-13-2010, 06:11 PM
hawkster's Avatar
hmmm liberty triples? dont think ive seen one, might have to actually read that
hawkster is offline
post #12 of 20 (permalink) Old 10-13-2010, 06:12 PM
JDS
JDS's Avatar
The 500 XC didn't have ves in 2000, but the xp sp did. My son has a 500 XC SP 2000.
JD
____________
2008 Polaris RMK 600-155"
JDS is offline
post #13 of 20 (permalink) Old 10-13-2010, 06:19 PM
hawkster's Avatar
i have actually never seen a liberty triple before, weird
hawkster is offline
post #14 of 20 (permalink) Old 10-13-2010, 06:55 PM
I just fix 'em...
IRONDOG's Avatar
The cranks are the same on VES and non-VES 800 engines and they all are subject to the same problems.
Jerry
www.snowmobileswapmeet.com
IRONDOG is offline
post #15 of 20 (permalink) Old 10-13-2010, 06:56 PM
I just fix 'em...
IRONDOG's Avatar
This is not a Liberty- it's a Fuji.
Jerry
IRONDOG is offline
post #16 of 20 (permalink) Old 10-13-2010, 07:00 PM
I just fix 'em...
IRONDOG's Avatar
The 1999 XCR700 is a Fuji with valves as are all XCR800 engines.
Jerry
IRONDOG is offline
post #17 of 20 (permalink) Old 10-13-2010, 07:25 PM
hawkster's Avatar
ahhhhhh right you are, Quoted from snowgoer mag: "The 794cc liquid-cooled Fuji triple is in its sophomore season. Three flat slide 38mm carbs feed the NiCaSil-lined cylinders through case reed induction. Digital CDI lights the fire and the spent charge exits through triple exhaust ports. "
Those ports change in size for maximum output at all rpm levels, thanks to Polaris variable exhaust system (VES). Polaris and Fuji engineers revised the system slightly for 2000 to make the engine fit in the smaller Gen II chassis. But, while they were at it, the engineers tweaked the system to gain about 3 hp, according to Polaris officials. They also used new springs in the VES that are quite similar to the ones suggested in a Polaris service bulletin last winter. Early season dyno pulls on the 2000 engine back up the Polaris hype: racers are getting 155-157 hp out of the triple in stock form, compared to a generous 152 hp last year. The power hit is immediate, with a broad and steep powerband.
hawkster is offline
post #18 of 20 (permalink) Old 10-13-2010, 08:32 PM
Quoted: 102 Post(s)
Sweet engine, hawkster! Gotta love the sound of those triple/triples!
BC_Dan is offline
post #19 of 20 (permalink) Old 01-07-2012, 03:31 PM
so after all this, I have a 99 RMK 700.....does this have the VES? Does it really make a big difference?
AvyDogHandler is offline
post #20 of 20 (permalink) Old 01-07-2012, 06:20 PM
69CRUZR's Avatar
No it does not, and you wont notice. Those engines are monsters by themselves! I have the 600cc version of the "big block" Liberty. Yours should look identical to this. The little black squares by the exhaust ports on the pics a few posts above is what an exhaust valve looks like. If yours had it it would be called the small block and have those black valves directly above the exhaust Y-pipe.
69CRUZR is offline
