92 Indy 500 efi - electrical question - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 50 (permalink) Old 02-23-2010, 04:19 PM Thread Starter
My 92 Indy 500 efi is still shutting down after runiing great for 6-8 minutes. The ready light goes out , everything shuts down , but if I hit the key quick enough , it'll keep running. While listening at idle , it revs slightly before it dies. I can get the same result unplugging the small , single wire from the CDI box. Is my CDI box bad ? I tried a different ECM with the same results. Please point me in the right direction , theres just too many wires !!
snowbound is offline
post #2 of 50 (permalink) Old 02-23-2010, 07:40 PM
Polaris87's Avatar
if it revs up before it dies, its running out of fuel. Other than that have no clue about those EFI's...
540 Open Mod
1995 Polaris Indy 500
White EPI primary spring with 10 weights
Purple EPI secondary spring, 45/36 HRP helix
Polaris87 is offline
post #3 of 50 (permalink) Old 02-23-2010, 08:47 PM Thread Starter
When the power goes down I imagine the fuel pump shuts down too. Hitting the key again powers the computer as well as kicks the pump on again. So far the only thing I know for sure is its not the ecm !
post #4 of 50 (permalink) Old 02-23-2010, 10:01 PM
TRH- Troll Raising Hell
SMFXRSB's Avatar
Relays? Try switching them
SMFXRSB is offline
post #5 of 50 (permalink) Old 02-23-2010, 11:10 PM Thread Starter
Both give the same results , unless both are weak ?
post #6 of 50 (permalink) Old 02-24-2010, 09:37 AM
Is the ECU showing any trouble codes?
post #7 of 50 (permalink) Old 02-24-2010, 04:04 PM Thread Starter
Unfortunately , no codes at all !
post #8 of 50 (permalink) Old 04-14-2010, 07:54 AM Thread Starter
Still looking for some help ! Fires great and runs for 5-6 minutes then power shuts off and everything stops. I've tried a different ECM , CDI box , relays , fuseable link and dropping resistor. Still did the same thing ! Where does the power to the ECM come from ? There are still no codes . I'm pullin my hair out !
post #9 of 50 (permalink) Old 04-14-2010, 09:03 AM
Check battery voltage.
12.5vdc with the engine off.
13.5 with it running and up to 14vdc after 3000 rpm.
If the battery is not charging/holding charge, the ecu will either shut down or go into "limp mode".
post #10 of 50 (permalink) Old 04-15-2010, 07:32 PM Thread Starter
Battery load tested fine. Sitting , its just over 12.2v , running at 3100rpm its at 14.2v. Still shuts down , its driving me nuts. Its almost like its on a timer ! Same run time each time. What am I missing ? Could a ground cause it ? What route does the power take to the ecm ?
post #11 of 50 (permalink) Old 04-15-2010, 08:11 PM
SMFXRSB's Avatar
Could be a fuel pump or fuel filter.... Could prime up and it takes that long to run out of fuel with the little that gets pushed through. It killing allows it to catch up then restarts.
SMFXRSB is offline
post #12 of 50 (permalink) Old 04-15-2010, 09:10 PM Thread Starter
I'll check the filter , but it doesn't explain the READY light going out before it dies. Thats why I've been leaning towards electrical. After a filter change and test , Can I run direct power to the pump from the battery so it won't shut off ? ( just a temporary test )
post #13 of 50 (permalink) Old 04-15-2010, 09:20 PM
SMFXRSB's Avatar
Yes you can
SMFXRSB is offline
post #14 of 50 (permalink) Old 04-16-2010, 06:36 AM
Look up member, Mrholmquist.
Send him an email or PM, he has the best info for trouble shooting these models.
post #15 of 50 (permalink) Old 04-16-2010, 08:07 AM Thread Starter
When I first posted this problem in December , that was the EFI guru I was hoping to hear from. I'll check fuel filter and pump first before I PM. Thanks .
post #16 of 50 (permalink) Old 04-22-2010, 10:03 PM Thread Starter
Filters and pump are fine. IS there a Mrholmquist in the house ? Sent PM a week ago and no reply. Seeking professional help.
post #17 of 50 (permalink) Old 04-23-2010, 09:00 AM
SD Rider
I don't think he makes it on here much. It's been a long time since I've seen him post anything. You might have better luck emailing him if he doesn't have it set up so it sends him an email when he gets a PM from this forum. If you can get a hold of him I'm sure he can help you figure some stuff out.
2008 Polaris IQ FST Dragon
2,552 Miles
jordandakota is offline
post #18 of 50 (permalink) Old 04-26-2010, 09:41 AM Thread Starter
Does anyone have contact info for Mrholmquist ? The email address I used from the forum came back.
post #19 of 50 (permalink) Old 04-28-2010, 07:24 AM
Here I am ....... sorry , havent been around much this time of year and also busy with other problems. I will try to set some time to think about your sled and get back to you in a few days
Mike
mlholmquist@sympatico.ca
mrholmquist is offline
post #20 of 50 (permalink) Old 04-28-2010, 01:52 PM Thread Starter
Thanks, I'm really frustrated ! I have a full wiring harness that was supposed to have been from a 92 , but it has a toggle switch near the relays ? My next plan is to replace each section of harness and test.
