Compression.... - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 21 (permalink) Old 02-06-2010, 08:48 PM Thread Starter
Need Snow!!!!!
Brummo's Avatar
Compression....
I just bought a 2004 700 Classic with 6K on it. It was owned by a Polaris Mech. and can see it was well maintained. I tought for giggles I'd do a compression test. Both cylinders were 120-122. It was not warmed up and doing furthur reading, I was not holding the throttle open. I am going to do it again tomorrow, but was just wondering what the change in compression might be with throttle opened.
It runs great and love the sled. I just have it in my head that I have to take it easy because of the higher miles...
Thanks Rob
Brummo is offline
post #2 of 21 (permalink) Old 02-06-2010, 09:57 PM
sounds like it's fine to me. I've done compression test, with throttle wide open and closed and my readings have always been pretty much the same. If your getting 120 with no throttle your in good shape IMO.
skiboyracing is offline
post #3 of 21 (permalink) Old 02-06-2010, 10:05 PM
oh canada hmmmhmmmhmm
clodev's Avatar
If you get 130's to 140's you are getting excellent compression
1999 SkiDoo Formula Z 500- mine
summer ride
2000 XL1200 Sportster customized
old rides
96 SkiDoo Formula SLS 500 -sold 1/31/13
81 AC Jag 4000 3500 miles sold 1/13/12
74 MotoSki Futura 340 2200 mls sold 6/15/12
Sold 12/19/9
Sold 8/19/9
"What ever you do don't eat the Calamari"
clodev is offline
post #4 of 21 (permalink) Old 02-06-2010, 10:19 PM Thread Starter
Need Snow!!!!!
Brummo's Avatar
Thanks guys, I guess I'm just a worry wort and don't want to hurt the sled, I mean I just got it...I guess I should just run it like normal, aye? I hope it has plenty more miles before an overhaul.
Brummo is offline
post #5 of 21 (permalink) Old 02-06-2010, 10:23 PM
I just fix 'em...
IRONDOG's Avatar
Thanks Rob
Check back with the mechanic and see if the pistons were ever replaced- checking compression is all well and good but you should be more concerned about piston to cylinder wall clearance. If those pistons have 6000 km on them I can guarantee you that they are at or past their wear limit. Big bore Polaris twins are hard on pistons, the skirts collapse over time and the potential for breaking a skirt off is much higher than wearing out piston rings. Two new pistons and gaskets are less than $200, money well spent compared to repairing a trashed cylinder or cracked crankcase.
Jerry
www.snowmobileswapmeet.com
IRONDOG is offline
post #6 of 21 (permalink) Old 02-06-2010, 11:07 PM Thread Starter
Need Snow!!!!!
Brummo's Avatar
Not sure if it means much but meant to say 6000 miles. I have no reason to fear the sled, it's just new to me and want to make sure it will last a while before any major problems. I don't forsee any, but like to know what I have before I get going too far.
That being said, the guy I bought it from said the compression was around 140psi, but at 120, I guess I'm glad it's not lower.
I did ask when I bought it about motor work done to it, and he said it's had nothing done and probably ouldn't need it for a while. Hope he's right.
Brummo is offline
post #7 of 21 (permalink) Old 02-06-2010, 11:18 PM
I just fix 'em...
IRONDOG's Avatar
If you want to make sure it will last awhile with no major problems changing the pistons would be a step in the right direction, IF they are original. Good compression is not a guarantee of a trouble free engine especially on a Polaris 700 twin with 6000 miles. It may very well have good compression right up until a skirt breaks off one of your pistons. Just speaking from experience here.
Jerry
IRONDOG is offline
post #8 of 21 (permalink) Old 02-06-2010, 11:27 PM Thread Starter
Need Snow!!!!!
Brummo's Avatar
Is piston/ring replacement easy enough to do? I'm pretty mechanically inclined, but something I've never done before. Is is a easy, for the most part, as getting a new piston and rings and swaping out the old ones?
Brummo is offline
post #9 of 21 (permalink) Old 02-06-2010, 11:34 PM
ayydammmn's Avatar
its fairly easy to freshen up that motor with new pistons rings etc.. id talk with the previous owner to get more advice as you said he being a mechanic, prolly could help u out with that. or at least give u some good directions. but as far as giving directions for a rebuild, my best advice is to get out there and attempt it...its the best way to learn if your a handson kinda person...
ayydammmn is offline
post #10 of 21 (permalink) Old 02-07-2010, 09:13 AM Thread Starter
Need Snow!!!!!
Brummo's Avatar
I'm hoping to run this the rest of the year and think about doing it next fall when the carbs and stuff need cleaning. I think it should last that long.
Brummo is offline
post #11 of 21 (permalink) Old 02-07-2010, 09:20 AM
AC Rider's Avatar
I really doubt you'd have any issues running it for jsut one season... It would be a good idea to do rings/pistons in the summer tho... I mean my sled only has 4k miles and im gonna do at least rings in it this summer
10/11 season: 1014 miles
My sled:
03 z440 sno pro w/ 3000 miles
-Fresh Top End
-Rejetted
-white handguards
-4 inch riser
-1.375 inch track
rest of the fleet:
2003 polaris classic 340 3000 miles(FS)-2003 polaris indy xc 500 2200 miles(FS)-2000 polaris xc 700 7000 miles-2003 arctic cat zl 600 3200 miles-1999 arctic cat zl500 4500 milesSOLD
AC Rider is offline
post #12 of 21 (permalink) Old 02-07-2010, 09:25 AM
josh
xc sp 500 rider's Avatar
that is not the big block 700 they only made the big block 700 2 yrs along with the 900 in 05-06.
xc sp 500 rider is offline
post #13 of 21 (permalink) Old 02-07-2010, 11:49 AM
TRH- Troll Raising Hell
SMFXRSB's Avatar
Could be your tester reading low... Can you compare it with another?
SMFXRSB is offline
post #14 of 21 (permalink) Old 02-07-2010, 12:14 PM
I just fix 'em...
IRONDOG's Avatar
The '04 700 Classic is a big block- has the belt driven water pump.
Jerry
IRONDOG is offline
post #15 of 21 (permalink) Old 02-07-2010, 12:17 PM
I just fix 'em...
IRONDOG's Avatar
One very important thing that needs attention on those Polaris 700 engines is the water pump belt- you should change it every 3000 miles. They do fail, and when they do you have no water pump or oil injection pump.
Jerry
IRONDOG is offline
post #16 of 21 (permalink) Old 02-08-2010, 04:51 PM Thread Starter
Need Snow!!!!!
Brummo's Avatar
Just did another compression test yesterday, not warmed up, but with throttle open. It appears the compression is closer to the 130 on both sides. I looked at it closer this time..
Brummo is offline
post #17 of 21 (permalink) Old 02-08-2010, 05:07 PM
69CRUZR's Avatar
Add gas and oil and run it! You have nothing to worry about. compression is great and its a fairly new sled. I know a guy with a 2000 sks 700, and if yours really is the "big block" engine with no powervalves, it has many miles to go. The guy absolutely pounds on his sled, and has had it since new. 9800 miles and never been apart! 130 lbs per side! I understand the preventative maintenace thing completely dont get me wrong, but going through all that work when it may not be neccessary would suck. The fact it was owned by a polaris mech is another great thing, you know dang well its been maintained! Get out there and ride!
if you notice a drop in compression come spring time then maybe pull it apart, but right now, with a brand new sled (to you), you and I know both you dont want to be tearing nothin apart, you want to ride it! And you should!
1998 Polaris XC600 (with a XCR sleeper hood on it)
2006 Polaris Indy 500
1969 Chevy C10 "69CRUZR"
-383 stroker 450 hp 479 ft lbs of torque
2006 Chevy Colorado -daily driver
New Project Truck, this one for my Pops!
1953 GMC 5 Window Shortbox Stepside
Drivetrain: 2006 5.3 Liter v8 with 4l60e from an 06 Silverado.
Full IFS front suspension kit w/rack and pinion steering, and 4 link rear from TCI Enterprises.
69CRUZR is offline
post #18 of 21 (permalink) Old 02-08-2010, 06:36 PM Thread Starter
Need Snow!!!!!
Brummo's Avatar
You hit the nail right on the head....
Brummo is offline
post #19 of 21 (permalink) Old 02-08-2010, 10:45 PM Thread Starter
Need Snow!!!!!
Brummo's Avatar
Awesome riding tonight....4 inches, so far, of nice powdery snow...
http://www.iowa-snowdrifters.org/
'10 Polaris Rush 600
3450 miles, Studboy Deuce Carbides
'04 700 Classic 7350 miles
M-10 suspension, Boyesen Reeds
Stud Boy Deuce Carbides
Brummo is offline
post #20 of 21 (permalink) Old 02-15-2010, 10:25 PM
What about the same year and size sled with 3400 miles on it and the compression reads 110 PSI each side w/o opened throttle? Both are equal but seem are lower. Could gauges be that much different?
04 700 Classic w/ M-10
90 Indy 500, 11,XXX mi
rbrumm is offline
