2006 polaris fusion - idle - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 14 (permalink) Old 12-29-2009, 08:58 PM Thread Starter
not really a major issue but im kinda wondering what it could be, i have a 06 600 ho with 109 miles on it, bought it about 3 weeks ago for $5,000 still in the crate with all updates done to it, i can start it first pull on half choke and flip it up right away and it will idle all day, however after riding on the trail and getting it warm it will idle for about a min or 2 and shut off, when trying to restart i have to hold the throttle to start it again, doesnt matter if its on full choke, half or anything, i can pull and pull for about 5 times and wont take off untill i push the throttle to it
i think maybe the plugs might be shot because the first tank of heavy premix to polaris specs (i installed NGK plugs since the first miles put on it, instead of the champion plugs) but it doesnt make since that i would have to hold the throttle to get it to start, however i havent had a great chance to just hammer on it the clean the plugs because of riding the only trips on the sled so far with my wifes young brothers (12 and 14)
i plan on putting the new plugs in before i go out this weekend but just wondering what you guys thought might be the issue
another thing i noticed is the difference in cornering, i had 93 indy sks before this and it almost seems that it handles 10x better then the fusion does lol, the fusion almost seems so high up and what not that it just wants to lift that front ski and roll lol
just the little things ive noiced if anybody else has any idea or input please feel free to share it
thanks andrew
Lind is offline
post #2 of 14 (permalink) Old 12-29-2009, 09:19 PM
sounds more like a fuel inadequacy than a spark issue to me
denjr1717us is offline
post #3 of 14 (permalink) Old 12-29-2009, 09:46 PM
not really broke in yet either
2003 classic very mint 2004 xc 700 sweet past sleds 89 488 indy trail 96 indy 500 2000 xc 500 before that many ski doo blizzards 9500's and 5500's
whiteghost is offline
post #4 of 14 (permalink) Old 12-29-2009, 09:48 PM Thread Starter
what you mean not broke in yet? just not enough miles on the engine? or i should run another tank of pre mix through it? ive been running polaris ves gold
Lind is offline
post #5 of 14 (permalink) Old 12-30-2009, 01:21 AM
Quoted: 101 Post(s)
Pretty much with all my newer Polaris sleds you have to crack the throttle to get 'em to start after running a while. It's a pretty common thing. Some guys have gone to a smaller pilot jet to give less fuel, I just know it's happening and give it a bit of throttle when I pull the rope...
BC_Dan is offline
post #6 of 14 (permalink) Old 01-08-2010, 07:26 PM Thread Starter
well i was running brp 7s that the dealership told me was a direct replacement for the champions that came stock with the sled, looked alright where tanish, however i looked and its suppost to have brp 9s so i replace them and went for a ride and the sled still idles from 1100 and works it way down till about 600 after it warms up for a few seconds. i pulled the plugs and they are pretty dark/wet when i pulled them
The main thing that is bugging the heck out of me with this sled is the fact that it starts first pull when cold but as soon as its warm doesnt matter if i ride it to a stop sign, hit the kill switch, and go to restart i have to pull and pull and pump the throttle enough/ try to hold it and pull to get it to restart
i should be able to restart the machine with one pull not using throttle or choke
i read in the manual about the oil they use to assemble the machines/keep the insides from rusting but how long should that last? there is roughly 210 miles on the machine
also the oil light is just about to come on (flashs every once in a while depending the bumps) is that normal for the amount of miles on have on it?
Hoping to get a few good answers to the questions, ive seen a bunch of people having the same issue with there fusions while searching on the net and nobody really has a clear answer to the problem, hoping to kick up a few ideas try and solve this problem
sorry for all the questions but im just used to my cheap sleds that ran great and now this year i went out an got a new sled to kinda treat myself (x mas gift) and its having issues lol
Lind is offline
post #7 of 14 (permalink) Old 01-08-2010, 10:04 PM Thread Starter
ive also seen alot about the carbs not being set up correctly
anybody seen the Jan article about improving idle on the fusion in Snow Week
will this correct the starting issue as well?
Lind is offline
post #8 of 14 (permalink) Old 01-17-2010, 10:45 PM
throttle me please
My 06 Fusion 600 HO does the same thing.Once its a little warm or even if its been sitting for 1/2 hour in cold weather ...I still have to open the thottle a little(no choke) to start it.To me this is a non issue because this is the only machine I've ever owned that ALWAYS starts.....-40 or spring warm....hot or cold.All ya gotta do is open the throttle a bit ...one or two pulls and your good to go.It smokes a little as well....but its ALWAYS reliable.I'll take a thumb on the throttle any day.
arctic sloth is offline
post #9 of 14 (permalink) Old 01-17-2010, 11:27 PM
jdubb11's Avatar
i have 05 600 and 500 and with both sleds if they dont start after two or three pulls ill give them a little gas and they start right up and run fine. i would not worry
you got to pay to play
jdubb11 is offline
post #10 of 14 (permalink) Old 01-18-2010, 08:44 PM Thread Starter
yeah, not really a big deal i guess, just kinda dumb, a new sled would do that, however i bumped up the idle screw and its worked out pretty good as far as the idle, i started mine on a few -10 days with full choke on first pull
the dealer said it needs the air more then the gas when it goes to start warm, i was thinking about messing with the air screw seeing how it runs pretty rich anyways
Lind is offline
post #11 of 14 (permalink) Old 01-18-2010, 08:59 PM
mattmoose's Avatar
from what i read u went from a hotter plug in the 7s to a colder plug in the 9s
that would explain the rich condition that u have now
mattmoose is offline
post #12 of 14 (permalink) Old 01-18-2010, 09:21 PM
2005 XCSP500
RedRocketSled's Avatar
also if your running a heavy pre mix that would f up the plugs. and also rule of thumb is you should top up the oil before the light comes on, the light is like the idiot light for the temp
Well seing as somone stole my xcsp now i own a 2011 switchback 136" with polaris hand-guards 162 studs woodies dually carbides and a tunnel bag
soon to come; exhaust, port & polish, clutching and gearing
Stolen
2005 Polaris XCSP 500
Mods:
Red lexan hood(see through), 1.5" pivot riser+ 2.5" that i CNCed, extended brake and throttle, sport teck hand guards, red chrome cobra windshield,1.25" ripsaw with 120 studs,and boysen power reeds.
Stolen form glen morris ontario, canada
RedRocketSled is offline
post #13 of 14 (permalink) Old 01-18-2010, 10:48 PM Thread Starter
i ran the 7s during the premix tank of gas, thats what the dealer told me was the correct cross ref from the champions that were in the machine, however they were wrong... lucky for them the 7s were still a nice tanish/brown, however i am running 9 sright now, neither one helped out with idle or starting when warm, also the machine calls for 9s, its under still has a one year polaris factory warrenty on it so i dont want to do anything to void the warrenty
also i didnt top off the oil on it because i wanted to see how long it would take before it came on, it never came on but it was close at about 250 miles roughly (if i hit a bump just right it would flicker and then go back off again)
i carry a full quart of ves gold in the back of the sled and always keep a gallon back at the shop, the sled gets oil added to it before i go out on every ride
ive heard of people going down 1 jet size to help/correct the idle and starting issue but im not going to do anything like that till after the first year if i dont extend the warrenty
Lind is offline
post #14 of 14 (permalink) Old 01-19-2010, 11:27 AM
2005 XCSP500
ya keeping an extra quart is good thats what i do but i dont know about the jetting
Stolen
Mods:
