sled idles fine, but stalls when given gas - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 6 (permalink) Old 12-29-2009, 02:51 PM Thread Starter
My friends sled will start up fine, but when he gives it gas it stalls, does this mean bad gas?
im guessing that the carbs need to be cleaned but want to hear some input first before i tear into it
it is a 2004 Polaris pro x2 800 they are mikunis, but they are flat on top, do they pull apart the same way as the round mikunis?
wheelmiester is offline
post #2 of 6 (permalink) Old 12-29-2009, 03:41 PM
Turtlemann14's Avatar
flat on top = cv carbs there is a vacuum boot under there (i believe) be careful
not going past idle suggest clogged main jets
Turtlemann14 is offline
post #3 of 6 (permalink) Old 12-29-2009, 10:13 PM
Repair Shop Owner
DoubleClutch's Avatar
Yes there a CV carb and they need cleaned. Take them off the engine and clean every thing. Oh and dont tear the rubber diephram.
01 Yamaha SXR 700
82 Polaris TXL340 (Oval racer)SOLD
80 Yamaha Exciter 440
79 Yamaha Exciter 440 (Oval Racer)
78 Artic Cat Pantera
72 Polaris Colt 295 ss F/A
Country Road Cycles
Motorcycle-Atv-Snowmobile Repair.
http://westernpasnowmobiler.com/foru...fad3dfa1b281c2
DoubleClutch is offline
post #4 of 6 (permalink) Old 12-30-2009, 10:38 AM Thread Starter
ok thanks, is there a link to information on how to clean them? cant find one on this forum for these particular carbs... is it similar to the round mikunis?
post #5 of 6 (permalink) Old 12-30-2009, 03:33 PM
Quoted: 102 Post(s)
Check here for specs for your sled.
Find the ATV Polaris part or Polaris snowmobile part you need, new ,used, OEM, aftermarket and performance parts, Polaris ATV Forums
According to this site, the sled has rack style TM-40's (flat slides). Removing the carbs and fuel bowls to access the jets in this carb is pretty simple and straight forward. The float bowl is pretty much held in place by the nut that holds the water trap hose and a small screw. Unscrew the small screw, then the nut, the bowl comes off. There should be 3 jets under the bowl, pilot, main, and starter jet. All can be easily removed for cleaning of the jet and for making sure the fuel and air passages are clear.
I have some pics of some racks disassembled for cleaning somewhere, if it would be helpful, I'll see if I can locate and post 'em
BC_Dan is offline
post #6 of 6 (permalink) Old 12-31-2009, 12:21 PM Thread Starter
Thanks BC, very helpful,
