antifreeze seeping through head bolts - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 8 (permalink) Old 12-28-2009, 01:27 AM Thread Starter
please help me i have antifreeze seeping through the head bolts on my rmk 800. No seals are leaking i just replaced the O-rings do i need to put some kind of silicone on the bolts?
proskier360 is offline
post #2 of 8 (permalink) Old 12-29-2009, 05:37 PM
we had the same problum with out xcr 40 when i blew it up i put blue rtv arround the head bolts when i put them in and dosent seep a bit
zach hulse is offline
post #3 of 8 (permalink) Old 12-29-2009, 05:49 PM
Quoted: 102 Post(s)
+1 on zach's suggestion. There is some kind of sealant from the factory on the bolts to prevent seepage, RTV seems to work fine to replace it.
BC_Dan is offline
post #4 of 8 (permalink) Old 12-29-2009, 06:10 PM
Thread Sealant.
burnoutking is offline
post #5 of 8 (permalink) Old 01-03-2010, 07:18 PM Thread Starter
thanks for the suggestions
post #6 of 8 (permalink) Old 01-03-2010, 08:34 PM
Renrip's Avatar
Should this be done on all top ends - or is that specific to this engine?
Renrip is offline
post #7 of 8 (permalink) Old 01-04-2010, 08:37 AM
PhazerManiac's Avatar
I had the same problem with my dirtbike, it would leak out of every bold, then i needed reserve one day i touch the anti freeze, which was a little hot, so i went to the mechanic next door and he said blue lock tight and tighten it 15 lbs more torque then wat the spec is, the spec says 25 lbs. Since then it hasnt leaked.
Born and bred to rip and shred
PhazerManiac is offline
post #8 of 8 (permalink) Old 01-04-2010, 12:36 PM
It's the same as a car engine. Bolts going into the water jacket should have sealant on them, or chances are pretty good they will leak.
'03 RMK 800, 159"
'96 Ultra SP 680, a few mods, 144" Leaves the nutsack dragging behind in the snow.
