how do i adjust idle? - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 11 (permalink) Old 12-10-2009, 11:19 PM Thread Starter
please help a real newbie out..I am the least mechanicly inclined person ever...I have 97 xlt touring...beautiful sled only 1750 miles on it..purchased this past summer. I had a local mechanic clean my carbs last month..Now that we finally have alittle snow to ride on I just had one question...sled seems to idle between 1800-2000 rpm...engine seems to run fine, so far no trouble, thing is great so far.. But the book says it should idle 1600 =/-200, which I take to mean mine is idleing alittle high...how do I adjust the idle down? is there an easy way to do this without screwing anything up? I really dont know much about this stuff, and would rather not mess with anything that can make things worse as I can not fix this myself... Im so mechanicly inclined that I cant even take my carbs off to clean myself...I thank you....
yankeeslover is offline
post #2 of 11 (permalink) Old 12-10-2009, 11:38 PM Thread Starter
also
it does seem to drop(idle) the colder it is out...is this normal? Like I said, for most part, it idles between 1800-2100
post #3 of 11 (permalink) Old 12-11-2009, 01:09 AM
Quoted: 101 Post(s)
I'm assuming you have three separate carbs on that engine. On the right side of the carbs is a small knurled knob. You will need to turn the knobs counter-clockwise equally until the RPM is where you want it to be. It shouldn't take much to drop 200 rpm. Try 1/4 of a turn on each carb and see how it runs.
Turning the knob counterclockwise allows the throttle slides in the carb to lower, which reduces airflow through the carb. Turning clockwise will raise the slides, increasing RPM.
BC_Dan is offline
post #4 of 11 (permalink) Old 12-11-2009, 06:35 AM Thread Starter
is this hard?
are these screws easy to get to? I dont want to turn the wrong screws....and also, should I turn these screws with the engine on or off? and I assume I do this after the engine has warmed up to proper temp?
post #5 of 11 (permalink) Old 12-11-2009, 10:19 AM
Quoted: 101 Post(s)
You should be able to turn 'em by hand, and with the engine running. There are only two screws to adjust; the idle screw is has a knurled knob, the air screw is smaller and has a slot for a screwdriver. You won't be able to turn the air screw with your fingers.
The critical thing is to turn each screw the same on all three carbs to keep the airflow through the carbs very close to the same. That will ensure smoothest idle as all three cylinders will be working the same amount.
If you choose not to adjust with the engine running, turn each screw equally a small amount and then start the engine to see the result. Both ways will work fine. I would also adjust on a warm engine.
BC_Dan is offline
post #6 of 11 (permalink) Old 12-11-2009, 04:22 PM
roadkill6972
roadkill6972's Avatar
how does that efect the oil injection
roadkill6972 is offline
post #7 of 11 (permalink) Old 12-11-2009, 04:58 PM
TRH- Troll Raising Hell
SMFXRSB's Avatar
It doesn't
Snow: The other white drug!
SMFXRSB is offline
post #8 of 11 (permalink) Old 12-11-2009, 05:53 PM
jamesu9165's Avatar
Quoted: 2 Post(s)
oil pump is driven by the crank so when idle slows the pump slows
RIP 91 Polaris Indy Trail,
85 Polaris Indy Trail... 488 motor from ^
74 Polaris Colt... custom 440 motor from ^
89 Ski-doo Formula Plus (521)
92 Ski-doo Safari L (377)... still in diagnostics phase
praying for snow and for the packers
jamesu9165 is offline
post #9 of 11 (permalink) Old 12-11-2009, 06:20 PM
On Wisconsin!!!
Octane's Avatar
Keep in mind that when the book says 1600 +/- 200 rpm, if its idling at 1800 rpm then thats the correct idle. I wouldnt mess with it if it were me.
You can use the knob thats on the carb rack if you really want to adjust the idle though. Make sure the engine has fully warmed up before you start adjusting the idle.
When you say Wisconsin, you said it all.
'01 Polaris Indy 600 XC SP EDGE XR
Powermadd articulating bar riser with 2" riser block (total rise of 4 1/2")
Pro-X seat
red Cobra low sno-x windshield
Pure Polaris handguards with Pure Polaris mounts
almond/blue drive clutch spring with 10-60 weights
121" x 15" x .91" track with 96 studs.
7,300 miles
Citgo Sea and Snow oil
Octane is offline
post #10 of 11 (permalink) Old 12-11-2009, 08:20 PM
jamesu9165's Avatar
Quoted: 2 Post(s)
i aree with Octane. i woulnt adjust it unless its pushing 2600. my colt idles on da at 1500 and the next at 3200. since it desnt engage till 4200rpm i dont me with it
post #11 of 11 (permalink) Old 12-12-2009, 01:51 AM
Quoted: 101 Post(s)
I'm pretty sure the XLT had 3 VM Mikuni round slide carbs instead of the TM rack style... the rack style is a LOT simpler to adjust with the one knob on the rack!
BC_Dan is offline
