Originally Posted by snax
i need a wiring diagram for my 92 indy trail i cant figure out the wiring ...
the voltage regulator dose not make sence on how it works if one yellow wire comes from the harness and to the voltage regulaor and rums back to the harness how dose it regulate for the head light ? it has one wire that runs in and splits right back in i am so lost
i just wanta run a head light and nothing else .....some one please help or point me in the right direction
thanx snax
It is a very simple system actually. The lighting coil is capable of producing in excess of 50 volts at high RPM.
. The regulator is screwen to the chassis and is designed to bleed the extra voltage to the chassis from that yellow wire. Think of it
this way, every time the voltage climbs over about 15 volts (target volts)
the regulator enables a circuit from the yellow wire to the chassis effectively shorting out the lighting circuit thus preventing the voltage to climb over the target voltage. As soon as the voltage drops below the target voltage level the regulator disables this circuit between chassis and the yellow and the voltage can start to climb again. The regulator should maintain the lighting coil voltage at very near to 15
AC voltsregardless of RPM.
I have a schematic for this sled let me know exactly what you are after and i will try to help
