Old 11-04-2009, 02:11 PM   #1 (permalink)
Klootzack
2000 Indy 500
Hi everyone, I would enjoy being able to join your forums on a regular basis! Now this all depends if I pick up a sled I'm going to look at this Sunday.
I already saw it once & put $200 down so the guy would hold it.... Now this is where I need all your help!
Overall, the sled looks great! No scuffs, cracks, sliders are good, carbides are great, track is in good condition! Low miles (2500)... what about the internals though???
- I'm bringing a gauge to test compression, I read it should be around 120psi?? I don't know how complete the test properly though? >> help!
- Any tips on checking other parts of sled?? I heard once you run it for 10 min then turn it off, pull the plugs, & listen for a hissing sound.. if there hissing this means your head gasket could have a break in it... I don't know :P
So please, any input would be great & hope to see you around the forums soon!
Sincerely,
Your friendly neighborhood Klootzack!
Klootzack is offline   Reply With Quote
Old 11-04-2009, 03:49 PM   #2 (permalink)
Stagesrt4
sofa king
Stagesrt4's Avatar
i believe you install the compression tester and then pull the cord 3 times...
My 99 indy 500 has 4333 miles and tested 132psi in ea cyclinder
Stagesrt4 is offline   Reply With Quote
Old 11-04-2009, 04:09 PM   #3 (permalink)
Klootzack
Are you supposed to pull the plug out of the other cyclinder while you are testing or do you leave it in? Do you know if the engine should be cold or run it for a bit first?
Old 11-04-2009, 06:07 PM   #4 (permalink)
Both plugs out and throttle wide open.
Warm or cold, there should only be a few psi difference in the reading.
Old 11-05-2009, 08:54 AM   #5 (permalink)
Klootzack
Thanks for the help guys! Anything else I should be checking? <.<
Old 11-05-2009, 12:19 PM   #6 (permalink)
Yes, loosen the track and check for wobble or tight rotation of any of the idlers on the skid (suspension). Replace any of the bearings that do not turn smooth or wobble.
Old 11-05-2009, 03:08 PM   #7 (permalink)
cvanmarter
~SUPER USER~
cvanmarter's Avatar
Check chain case for fluid level, or signs of a leak. wiggle skies, handle bar check for too much play. Put the rear up on or test ride if possible to check clutch engagment and belt
2000 Polaris XCSP 500
http://www.powerhousehotrods.com/#
cvanmarter is offline   Reply With Quote
Old 11-06-2009, 04:48 PM   #8 (permalink)
Klootzack
Thanks for all the help, I'll let you know Sun how she looooks & if she looks good I'll post some pics
Old 11-09-2009, 10:35 AM   #9 (permalink)
Klootzack
Well picked her up yesterday! Shes a pretty mama, 120 PSI each cylinder, No leaks, Squeeks, everythings tight, & clean! Thanks for all your help folks, I'll post some pics l8r tonight! See ya out on the trails d{-_-}b
