Old 11-01-2009, 08:52 PM   #1 (permalink)
xc sp 500 rider
xc sp 500 rider's Avatar
xc sp 500 problems, cdi maybe?
hi,
took my sled out for a ride around the house and it is running very crappy, it is back firing and not just running right, my dad thinks its the cdi, or the throttle block saftey switch, can you test these, if so how? he doesnt think anything is wrong with the motor hes pretty sure its electrical. we put in new plugs and cleaned carbs.
thanks!
2006 edge touring 600 for sale 4250$ p.m me if interested!
2003 classic touring 500
2001 xc sp 500 mine
Polaris kid for life
SUMMER SUCKS!
for sale
xc sp 500 rider is offline   Reply With Quote
Old 11-01-2009, 10:35 PM   #2 (permalink)
JheLrey
TRH- Troll Raising Hell
JheLrey's Avatar
Did you let it get up to temp? Mine backfires every so often and because this sled is new to me, I can't tell you much more...
Old 11-02-2009, 08:22 AM   #3 (permalink)
xc sp 500 rider
ya, and it idles just fine.
2001 xc sp 500 mine
SUMMER SUCKS!
for sale
Old 11-02-2009, 08:36 AM   #4 (permalink)
mrholmquist
if you think the throttle safety switch is causing the cutting out make sure the throttle cable is not too loose. Adjust the cable to between 0.010" and 0.030" free play at the throttle block. Many people disconnect or bypass this safety switch when all that is needed is a simple cable adjustment.
Other suggestions I can offer is a compression test , check piston skirts and also
plugs and plug caps. If the main jet was plugged in one or more carb it could idle ok but not deliver fuel when the throttles are opened. try to narrow down wheather the backfiring is coming from one particular cylinder. Pull the air box and see if it is backfiring through one of the carbs or both
mrholmquist is offline   Reply With Quote
Old 11-02-2009, 10:49 AM   #5 (permalink)
XLT Spartan
XLT Spartan's Avatar
It sounds like your carbs are not properly adjusted. I would start there. Make sure your air screws are set correct (should about about 1 turn out) and everything is synced. It's totally possible that it could idle correct and then backfire when you ride it if this is not right. If the engine is cutting out then it could be the throttle safety switch, but if it's just rough and popping it's probably the carbs adjustment. You may have a combo of both.
Toys:
93 Vmax 600
94 XLT Special
99 XLT Touring
XLT Spartan is offline   Reply With Quote
Old 11-02-2009, 01:23 PM   #6 (permalink)
JDS
JDS's Avatar
It's not the CDI. Check for a mouse house in the exhaust or intake.
JD
____________
2001 Arctic Cat ZR500
1991 Honda Fourtrax
JDS is online now   Reply With Quote
Old 11-02-2009, 02:14 PM   #7 (permalink)
ppolaris1010
Here is the best way to check if a switch is bad and causing it to lose spark for a second.There is a single black wire with a white connector it should be down by your pull cord where it goes into the motor.You might have to take the airbox off to find it that will disconnect all your shut offs and safety switches.When you unplug it you wont be able to shut the sled off until you plug it back in.If the problem goes away with it unplugged then you know one of the switches is bad or adjusted wrong. If it still does especially when it gets hot then its probably your cdi. Or like jds said a mouse got into it.Check under your handle bar cover they love it in there. If your still unsure try choking it when it starts to backfire see if that helps it could be a fuel problem but not to common with backfiring could be a lean misfire.
Old 11-02-2009, 03:45 PM   #8 (permalink)
polaris rider
PR (polaris rider)
polaris rider's Avatar
throttle safety switch is more a prob with ACs.. and maybe it was jsut backfiring cuz it was warm? What was the temp outside? And my sled has backfired on me about 4 times, and ive started it about 15
1999 AC zl 500, 3k miles2003 polaris classic 340 1200 miles-2003 polaris indy xc 500 1500 miles-2000 polaris xc 700 6500 miles-2003 arctic cat zl 600 1500 miles
"Dont let fear and common sense stand in your way!"
polaris rider is online now   Reply With Quote
Old 11-02-2009, 05:15 PM   #9 (permalink)
TwinsofMLB
Themach1king
TwinsofMLB's Avatar
If it's too warm you'll definitely get backfire and poor performance...
Yes I patented that
Old 11-02-2009, 05:29 PM   #10 (permalink)
xc sp 500 rider
about 20 degrese its not to warm! there are no mouse chewed wires or mouse houses in the exhaust pipe, the carbs are totally cleaned, runs good on both cylinders , and it just had a new top end, we took apart the airbox to clean the carbs, and it has new plugs and good spark, its got to be either the throttle saftey switch, cdi, carbs not right or throttle cable loose. is it possible to test cdi without putting a different cdi on the sled and seeing if i still have probs? ill unconnect that black wire and see if its one of the switches.
2001 xc sp 500 mine
SUMMER SUCKS!
for sale
Old 11-02-2009, 07:47 PM   #11 (permalink)
xc sp 500 rider
if it is a mouse nest in the exaust pipe how do you get it out because it seemed to run better strait piped. so there might be one in the can
2001 xc sp 500 mine
SUMMER SUCKS!
for sale
Old 11-02-2009, 08:20 PM   #12 (permalink)
tundrapolaris
tundrapolaris's Avatar
What will cause backfiring is poor compression on a cylinder. After sitting all summer i've seen rings slug up and seize causing low compresion. They will idle but when reved it will bypass. My 600 sp did it. You can pull a exhaust valve and look inside for abnormalities.
tundrapolaris is offline   Reply With Quote
Old 11-03-2009, 06:33 AM   #13 (permalink)
xxxthebxxx
XTBX (Anthony)
xxxthebxxx's Avatar
take off the exhaust and look inside.
Winter:
2006 Arctic Cat Crossfire 600 EFI 136" MINE!
1999 Ski-Doo Mach 1 Triple 700
2002 Polaris Edge X 800
2001 Arctic Cat ZR 600 EFI
1989 Yamaha SRV 540
Summer:
1999 Polaris Trailblazer 250 Quad
2004 Yamaha Wolverine 350 4x4 ATV
2001 Caravelle Interceptor 21' Boat
Past Machines
2000 Ski-Doo Formula Deluxe 380-9/29/09
She will be missed
1991 Suzuki LT 80-9/08
1990 Yamaha Sno Scoot-2007
1996 Larson 16' Bowrider-2007
www.snobusters.com
LET....IT....SNOW!!
xxxthebxxx is offline   Reply With Quote
Old 11-14-2009, 01:58 PM   #14 (permalink)
xc sp 500 rider
i ran it today and disconnected the wire that turns off all the switches it did not help, it sounds like a lean misfire to me, and my dad thinks one cylinder isnt getting fuel. any ideas?
2001 xc sp 500 mine
SUMMER SUCKS!
for sale
Old 11-14-2009, 02:08 PM   #15 (permalink)
Check the plug color to be sure.
Old 11-14-2009, 02:13 PM   #16 (permalink)
xc sp 500 rider
dad told me same thing!
2001 xc sp 500 mine
SUMMER SUCKS!
for sale
Old 11-14-2009, 07:22 PM   #17 (permalink)
tundrapolaris
Have you done a compression test yet? I still think you have blow by.
Old 11-14-2009, 09:15 PM   #18 (permalink)
polaris rider
PR (polaris rider)
yea id check compression.. could have blown a cylinder
