10-31-2009, 09:11 PM
The way it goes
Can i draw 3.2 Amps from my xcsp?
Heyy i just ordered a nice new expensive heated vest, But never thaught of checking the power draw till now (oops) It draws 3.2 amps.
Can anyone tell me if i can safely Draw 3.2 Amps from my 2001 XCSP600? The sled doesnt come stock with a accessory plug, and the one on it is thin and only puts out 8.7 Volts. Mabye i can wire it in somewhere else?
Also can u tell me if its normal for my headlight to be dim at idle???
Thanks alot!!!!!
Reason: maclean
10-31-2009, 09:15 PM
not sure about the vest.. but if your sled doesnt have a battery then thats why your light is dim. the engine produces more power at higher rpms which is why your light brightens up once you move.
1989 Yamaha Phazer 485
10-31-2009, 09:22 PM
The way it goes
Aw ic, Thanks for the fast reply!
10-31-2009, 11:29 PM
TRH- Troll Raising Hell
A heated vest! Sheesh! Wear another sweatshirt!
11-01-2009, 06:39 AM
The way it goes
did i say i wanted to wear another shirt? No, i want a heated vest so all i need to wear is a sweater and jersey.
11-01-2009, 12:03 PM
your system at high speed will supply aprox 15v at high speed . If you multiply 15 x 3.2
it would seem your vest would draw around 48 watts. If you add all the loads you have, hand warmers and thumb, headlights and other lights in watts and compare it to the specified output of your stator you will get a pretty good idea of the outcome. It will definitely cause the headlight to dim considerably at low speed as the stator output is lower. Also consider if something goes wrong with that vest like a broken wire or whatever you may be in for a cold ride home if you are underdressed for the weather conditions.
11-01-2009, 01:42 PM
Very good point.
11-01-2009, 01:46 PM
And or In case you burn up your stator by over loading it. Which you might be in for a cold walk home. And thats never a cheap part.
11-01-2009, 06:32 PM
The way it goes
Yeah i only plan on using it around home and with friends anyway.
11-01-2009, 06:56 PM
XTBX (Anthony)
Still even for that time it will overload.
Winter:
2006 Arctic Cat Crossfire 600 EFI 136" MINE!
1999 Ski-Doo Mach 1 Triple 700
2002 Polaris Edge X 800
2001 Arctic Cat ZR 600 EFI
1989 Yamaha SRV 540
Summer:
1999 Polaris Trailblazer 250 Quad
2004 Yamaha Wolverine 350 4x4 ATV
2001 Caravelle Interceptor 21' Boat
Past Machines
2000 Ski-Doo Formula Deluxe 380-9/29/09
She will be missed
1991 Suzuki LT 80-9/08
1990 Yamaha Sno Scoot-2007
1996 Larson 16' Bowrider-2007
www.snobusters.com
LET....IT....SNOW!!
11-01-2009, 08:10 PM
The way it goes
How do u know? My boss figured it out and it seams the vest only draws the same power as two tail lights... Which is nothing rly.
11-01-2009, 08:39 PM
XTBX (Anthony)
then its not that bad
Winter:
1989 Yamaha SRV 540
Summer:
Past Machines
She will be missed
www.snobusters.com
LET....IT....SNOW!!
11-02-2009, 06:30 AM
The way it goes
Yeah it doesnt seam like alot at all,
Now i find this weird, on my sled, i CANNOT get a Volt reading from any wire except the two wires going to the off switch. And they read the good 14.5-14.8 Volts?
11-02-2009, 08:26 AM
try switching your meter to AC volts to check voltage anywhere on the sled except where it it rectified to DC volts
11-02-2009, 05:15 PM
The way it goes
OK thanks alot! I realy appreciate the help
