I hear you on the reliability issue. Walking back to the truck sucks
Being towed by a Cat sucks even worse!!
The 700's don't have near the problems the 900's have. I ride with guys that have both, the 700 is stock, the 900 has the radiator delete. On some days, the 900 overheats, usually if the weather is crappy and conditions won't allow you to ride fast enough to toss snow onto the exchangers. The 700 has no delete, and has had no issues with heat, although his temps are still quite a bit hotter than my 08 600 when riding in the same snow. When he's running 150 i'm about 115. The full tunnel cooler of the 07-up models really does a number in cooling. But most guys that do the delete find they run cooler temps without the front radiator and lose the lbs in the process. That's definitely a win/win!
I think the push arm/torque link is a big help in keeping the engine planted, especially the 900. Those first years, guys were going through an 080 belt a ride, sometimes two. That's just stupid. The newer (more spendy) 111 belt helped eliminate that, it's one tough belt. Keeping the engine planted with a torque link and push stop helps keep the clutches aligned which really helped those 900 guys keep the belts from self-destructing. If you are not having many belt issues, you probably don't need one. I don't think it helps with vibration, with that long stroke that engine is going to vibrate, that's just what they do. But if you have breaking belts, it's one thing to try. The 900 motor mounts have also been a problem in some sleds as well; the stock ones were pretty soft and with the amount of torque that engine has, they frequently break, allowing the engine to shift and mis-align the clutches. Viola. More broken belts. That is worth checking, although with all the stuff in the way, it's almost impossible to get to those mounts.
Thanks for the offer of your expertise, that is why I really like this forum.. guys that have knowledge and skill are willing to help those that don't. The rest of us just make stuff up
