Old 10-30-2009, 10:34 PM   #1 (permalink)
quadturbo
89 indy 500 intake gasket?
I know it doesn't use one but for some reason my intake boots aren't mating up with the engine, its leaving gaps. So am I doing something wrong or should I go buy some gasket material and make some?
89 Indy 500
quadturbo is offline   Reply With Quote
Old 10-30-2009, 10:43 PM   #2 (permalink)
IRONDOG
You probably have aftermarket intake boots- they are junk and deform exactly as you described when installed. The factory boots DO NOT deform when tightened up. Look on eBay for good used ones- they have an "O" ring on the back, no gasket needed. A coating of Threebond 1194 always helps when installing the boots.
Jerry
www.snowmobileswapmeet.com
Old 10-30-2009, 10:47 PM   #3 (permalink)
stangcruzin
stangcruzin's Avatar
Those intake flanges seem to rust from the inside and deform over time.(from my experiance anyways).You need a good seal or the engine will self destruct.As far as a gasket,there aren't any the rubber makes the seal.DO NOT use silicone,for gas eats that stuff.
Replace the intake boots with good ones.
stangcruzin is offline   Reply With Quote
Old 10-31-2009, 04:31 PM   #4 (permalink)
quadturbo
ordered some oem ones, thanks
89 Indy 500
Old 11-05-2009, 04:22 PM   #5 (permalink)
quadturbo
bump for another question, how much oil does the chaincase take? I cant find this info anywhere
89 Indy 500
Old 11-05-2009, 04:23 PM   #6 (permalink)
8oz.
Old 11-06-2009, 06:03 AM   #7 (permalink)
kikkinurazz3
12 oz if reverse was installed
2003 Arctic Cat F-7 700
1999 Arctic Cat Thundercat 1000
!996 A Cat Panther 440
!995 A Cat Panther 340
!997 Polaris Indy 500 Sport
1995 Polaris Indy 440
1983 Indy 500 Trail- Parts sled now
!996 Yamaha V-max 600-Sold
kikkinurazz3 is offline   Reply With Quote
