Old 10-30-2009, 07:22 PM   #1 (permalink)
miller12083
99 xc sp 600
Last year i bought my first sled its a 99 xc sp 600. I have a few questions about it. What rpms should the clutch engage at? What compression should the motor be at? I also heard that the 700 cylinders would work on my motor if i changed the pistons and heads. Is this true? It engages at around 3400rpms and seems slow out of the hole. My compression is at 110 on both cylinders.
miller12083 is offline   Reply With Quote
Old 10-30-2009, 09:55 PM   #2 (permalink)
Flip&Roll
I have the same machine and mine engages at 3500. Has the dark blue primary spring. It actually has a very impressive take-off and will lift the skis easily with proper traction, but I have a EPI Pro clutch kit ready to be installed simply because I love the arm-stretching holeshot they add. My brother installed this on his ZR and it turned it into a takeoff monster. Unbelievable difference throughout the entire powerband in fact.
These engines are fairly bullet-proof when left alone and were advertised as 118hp back then. I don't know how much the 700 heads might add but the stock 600's are built tough and dependable. I would probably do a simple re-ring to get the compression numbers back up to factory specs again. Then work with the clutch; weights, springs, kits, etc.
Adding the bigger bores would also involve re-jetting, tuning, and clutching perhaps.
Flip&Roll is offline   Reply With Quote
