Old 10-27-2009, 06:34 PM   #1 (permalink)
dalton5989
SS VES Valves
Any body know where I can get some stainless steel exhaust valves
for my 02 edge x 800?
2002 Polaris Edge X 800 Twin-6,700 mi
1997 Polaris XCR 600 Triple-11,100 mi
1987 Yamaha Inviter 300 Single 1,900 mi(Brothers)
all stock
dalton5989 is offline   Reply With Quote
Old 10-27-2009, 06:59 PM   #2 (permalink)
dalton5989
I found this: Shopping Cart Items Is that one side or both?
all stock
Old 10-27-2009, 07:48 PM   #3 (permalink)
BC_Dan
Your link didn't point to anything. If you look at the diagram under "cylinder", you can see the guillotine that needs to be replaced with SS as part number 23. If you have not changed the bellows or spring, you may want to change those as well. You will need one guillotine (and bellows and spring) per cylinder.
The stock aluminum ones can melt and send parts into the cylinder, creating quite a mess. The SS is good insurance to keep that from happening...
Old 10-28-2009, 07:33 AM   #4 (permalink)
Jimboat
so, the ones in the diagram are the OEM aluminum gillotines, right? Does anyone know where to get the SS gillotines?
/Jimboat
2004 700 Edge Touring
Jimboat is offline   Reply With Quote
Old 10-28-2009, 12:38 PM   #5 (permalink)
BC_Dan
The aluminum ones aren't sold any more, when you order from any dealer, you get the SS ones.
Old 10-28-2009, 01:47 PM   #6 (permalink)
Jimboat
hmmm...interesting. Do you know when they started supplying SS as the replacement part? (i bought some 2 years ago....now i'm wondering if they were SS or not).
/Jimboat
Old 10-28-2009, 01:56 PM   #7 (permalink)
BC_Dan
Not sure, but the old number 5132690 has been substituted by 5134492, which is the stock number for the 2005 model and is SS. If you have the part number 5134492 then it's SS.. or pull the valve and check with a magnet. I'm betting if they are 2 years old, they are SS, unless the parts were sitting on the dealer's shelf for a long time... (not likely, but possible..)
Old 10-28-2009, 02:09 PM   #8 (permalink)
Jimboat
i hope that the pn is on the part. don't think i can check with a magnet, because SS is non-magnetic and aluminum is also non-magnetic.
/Jimboat
Old 10-28-2009, 03:27 PM   #9 (permalink)
BC_Dan
Pure stainless is not magnetic, but depending on the amount of other things in the batch, it may show magnetic properties. If the valves have chromium in 'em, they may be magnetic. For example, the wif has SS Reverewear pots and pans, not magnetic. But she has some SS bowls that are. Go figure.
Another way to check... the aluminum valves are solid and smooth all the way across. The steel ones have hollowed areas on the back to decrease weight. If your valves are not smooth all the way around, then they are SS
Old 10-30-2009, 07:00 PM   #10 (permalink)
Farnzworth_03XC
I just added SS valves to my 03 XC 800.
A good indicator if they are SS or not is weight. Aluminum have hardly any weight to them. Not much help though if you dont have the 2 side by side to compare
The Polaris SS valves I received are hallowed out on the engine side as mentioned above by BC Dan. The core or depression doesnt go all the way through - but its definately noticeabe.
My old aluminum ones where a solid profile all the way down the guillotine.
Farnzworth_03XC is offline   Reply With Quote
Old 11-01-2009, 06:47 PM   #11 (permalink)
farmaloose
twins rule!
ves
are the 800 and the700 ves valves interchangeable on some years? I just cleaned mine on 2002 700 with 8000 miles on it, they show some ware but looked good. I see low milage ones on ebay in good shape for cheap, but most or 800 0r 600 valves, my dealer wants 85.00 each for new ones. from the looks of mine,im not scared of low milage used ones in good cond. if they will fit, or am I just stupid?
farmaloose is offline   Reply With Quote
Old 11-01-2009, 08:01 PM   #12 (permalink)
BC_Dan
The valves are specific for the engine, a valve for a 700 will be smaller than an 800. The guillotine part of the valve is the shape and size as the cylinder.
Old 11-05-2009, 02:55 PM   #13 (permalink)
dalton5989
I got my ss valves today
heres what the ss valve looks like compaired to my old one
everything in the pics is included with the kit.
all stock
Old 11-05-2009, 03:26 PM   #14 (permalink)
Jimboat
cool! where did you get them? and how much $ were they?
did you have to ask for SS or is that what ships as standard part now?
/Jimboat
Old 11-05-2009, 03:55 PM   #15 (permalink)
Farnzworth_03XC
I ordered mine from partspitstop.com - they sell Polaris OEM parts at a reasonable price (Grand Rapids, MI).
Like most dealerships, they have a web app that lets you see exploded views of the sleds various assemblies - and you can see pricing and add parts right into your basket.
There are a ton of Polaris authorized dealerships out there that have this feature.
From what I can gather - aluminum valves are no longer an option.
When you order - you will most likely get the SS valves. You may see a "part number xxxx - substituted by xxxx in the description.
I also believe if your sled had aluminum valves - the springs may need to be updated as well to correct spring pressure (heavier valve??). I ordered new springs, valve nut, bellows and valves just to be sure i have the updated hardware. I know my sled was bone stock - and the springs that came out where not the same type as the new ones sent.
Some of the vets here can confirm if this is true or not.
