the pilot air screws really has nothing to do with syncronizing the throttle slides and they should be adjusted to whatever amount of turns out the manual or the hood sticker specifies for the model sled in question.
When you syncronize the carburetors what you are trying to acheive is to make all the slides working in unison. Or in other words at any given throttle position all the carbs will be open the same amount. Which will allow each individual cylinder to contribute equally for power output.
This will have a huge effect on engine performance.
If the carbs are out of sync some of the cylinders will be working harder than others and the weak cylinders will be lagging back robbing power.
TwinsofMLB if you have not ever properly syncronized your carbs chances are your sled is not performing to it's potential.
Since the slides are actuated by individual throttle cables it is actually the cables that you adjust to sync the carbs. You have to make the adjustment at part throttle when the cables are actuating the slides.
The other part fo syncronizing is to adjust the slides so that they are at exactly the same height when the throttle is released and the cables are slack. This is done using the idle stop screws which stop the slides from closing completely when the throttle is released. By adjusting the idle stops you are controlling how far down the slides will drop when the throttle is released . Here are some links to pages from the factory repair manual as promised.
pilot air screw
Snowmobile Fanatics
carburetor syncronizing procedure page 1
Snowmobile Fanatics
carburetor syncronizing procedure page 2
Snowmobile Fanatics
The uni sync tool is a little tricky to use at first. I much prefer to use the mercury sticks. Especially on three or more cylinder engines. The reason being that you can watch all the carbs at the same time . The uni sync requires you go back and forth between the carbs , take a reading make an adjustment repeat bla...bla..can be a pain on a three cyl . There are people who have made their carb syncronizer tools themselves at home sometimes using less dangerous liquids than mercury.
Motion Pro SyncPro Carburetor Tuner - DennisKirk.com
I tried to download the images to my gallery on
this forum but they would not load
