Old 10-16-2009, 11:22 PM   #1 (permalink)
cliffhanger
97 XLT special limited woes
Hi, I'm new to this site so I'm not sure how this works but I'm looking for some help in making a call on this sled. Anyway, season before last the sled was running fine. Went out to start it one day it backfire and blew the airbox ten feet into the air. Several others tried and got the same results trying to figure out the problem. I was advised that the 598cc triples had a pressed crank that had a habit of twisting. Is this true? I was also told that the cost to repair/rebuild would not be worth it. All the engines I see for this new generation style are going for $500 to $700. The sled is in pretty nice shape. Not show room by any means but I'm not sure if its worth a $700 engine. Will other Polaris engines hook up in this 97 body style. If yes then which ones? Are these engines less expensive? Does the crankshaft sound like the problem to you seasoned mechanics? And finally should I even try to fix or part it out and sell it in pieces. Hope I can get some advise, Thanks
cliffhanger is offline   Reply With Quote
Old 10-17-2009, 08:32 PM   #2 (permalink)
Most guys are now going to WC (water craft) engines as replacements for reliability and big hp gains.
Old 10-17-2009, 08:52 PM   #3 (permalink)
cliffhanger
A little confused by your response to my question
Old 10-17-2009, 08:54 PM   #4 (permalink)
Rather than fixing the current engine, many are simply replacing them with WC triples instead. More hp for the size and lots more bolt on hp boosters too.
Old 10-17-2009, 08:59 PM   #5 (permalink)
cliffhanger
And these are cheaper and would bolt right up without a ton of modifying?
Old 10-17-2009, 09:15 PM   #6 (permalink)
I don't know about cheaper, but they will usually just bolt in.
To answer the question about the crank, yes, some are known to to actually go out of phase. The fix is to have them retrued and balanced and welded to prevent that from happening again. Usually not that expensive. (I think its about $150 or so)
Old 10-17-2009, 09:29 PM   #7 (permalink)
cliffhanger
Thanks!!! thats what I was looking for. I appreciate it
09 Skidoo MXZ HO 600 e-tec
01 Polaris xcsp
98 ZL 500
97 XLT 600
Never say Never
Old 10-18-2009, 09:53 AM   #8 (permalink)
Polaris87
Polaris87's Avatar
I thought the 97's had a 4 line oil pump that fixed the pto bearing failure...My 95 xlt only has a 3 line oil pump and the pto oil journal was actualy smaller than the rest. The 3rd bearing in on the pto side went and I replaced the crank with a used one and drilled out the oil jornal bigger. This is suppose to fix the oil troubles. But I thought they had that all sorted out in 97...not sure though.
1995 Polaris 600 XLT Touring
1995 Polaris Indy 500
Polaris87 is offline   Reply With Quote
Old 10-19-2009, 09:05 AM   #9 (permalink)
They did, however, there was still the occasional engine that the crank would go out of phase.
