Old 10-08-2009, 12:47 PM   #1 (permalink)
XCR KDX NJ
Polaris
88 Trail 488- oil pump pumps only one hose
I did a test to see if the oil pump was working correctly, and after turning the motor over dozens of times, oil only came out of the right hose. I took the left hose off and put piece of wire through it, there was nothing blocking the hose. I poked into the pump itself where the hose clamps to and it didnt seem blocked. I then took off the top cover of the oil pump, the four screws, exposing the top of the inside of the pump, looking down at the top of a piston. I removed the piston with a needle nose and pulled it out. I dont know why I did this, but it was hard to put back in. I noticed a spring at the bottom, and gears. I blew some of the oil that was at the bottom out, so the piston would go in easier. I put it back in, setting it to the bottom, but it still pokes out a little, and isn't lined up the way I found it. Did I screw myself badly? Can this be fixed without taking the pump off the motor? THANKS
1995 XCR 600 (blown crank, dropped in a nice 580)
1991 Indy Sport 440 fan
1989 Indy 400 lc
1988 Indy 650 lc
1988 Indy Trail 488 fan
1980 TX 440 air
XCR KDX NJ is offline   Reply With Quote
Old 10-09-2009, 11:52 AM   #2 (permalink)
stickshift69
stickshift69's Avatar
Is that the same hose that supplies oil to the piston that is melted?
2003 ProX 700
1993 XLT SKS
1996 XP800, Full Mod
stickshift69 is offline   Reply With Quote
