.659 volts equates to 4.2 degrees throttle angle on the select monitor. To set to 0 degrees as the book says which is of course the best way to do it you need to adjust the voltage to between .480 and .484 volts.
.480 volts is 0.0 degrees on the select monitor
.484 volts is 0.2 degrees on the select monitor, NEVER NEVER adjust to below .480 volts.
With the throttle closed and the stop screw backed out and cable loosened adjust to between .480 and .484 volts. After that is set turn the idle screw back in until the voltage is close to .659 volts which will give you around 4 degrees and that should give you an idle speed close to the specified 1900-2100 rpm.
Anything below .480 volts and the ECU will default to around 12 degrees even though the throttle is closed.
The select monitor is of course the easiest way to do this as well as the only way to verify the mixture screw is adjusted correctly and also see that the other sensors are reporting proper temperatures and so forth, I decided not to build any more interface cables for the software program this year but I have had a lot of requests to do so , I may look into it again.
I should also mention that after you have finished with the above settings do not forget to re adjust the throttle cable clearance to between 0.010" and 0.030" or you could have problems with the throttle assurance safety switches.
