Jackshaft bearing - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 11 (permalink) Old 03-25-2009, 05:06 AM Thread Starter
Hoss98's Avatar
Jackshaft bearing
Hi folks, I've got an '08 Polaris 600 RMK. I want to get some grease into the bearing on the jackshaft. There's a decal on the airbox that says grease the jackshaft as per the owners manual. The owners manual says to grease the jackshaft. Not much help there. How do I access the fitting to to this. My buddy has an 07 RMK, and he got his with a needle my removing the airbox. I took out my airbox, but I'm not seeing anything. Any help? Thanks.
"Conditions are so much more like today than ever before"
'08 Polaris 600 RMK 155"
'02 Polaris 700 RMK 144"
Hoss98 is offline
post #2 of 11 (permalink) Old 03-25-2009, 08:42 AM
Quoted: 101 Post(s)
I wouild like to know this too. I asked the mechanic at the Polaris dealership here, he had no clue as to how to get grease in there. Irritating, to say the least. It sure would be nice if they made things EASY...
BC_Dan is offline
post #3 of 11 (permalink) Old 03-25-2009, 10:16 AM
You use a needle and slip it under the seal.
post #4 of 11 (permalink) Old 03-28-2009, 07:20 PM
arcabuddy's Avatar
You may have to remove your secondary to see a grease nipple, pretty easy to do!
1997 Indy trail Touring; 2008 Skandic SUV 600SDI H.O.
arcabuddy is offline
post #5 of 11 (permalink) Old 03-28-2009, 10:23 PM
Quoted: 101 Post(s)
There is no grease nipple on the bearing retainer. There is no small hole to grease with a needle. About the only way would be to remove the retainer and do like RJ said and slip some grease under the seal. What a pain in the butt. Especially when the label says to make sure to grease the bearing. Sometimes Polaris is such a treasure. At least the jackshaft bearing does not fail as frequently as the driveline bearing!
BC_Dan is offline
post #6 of 11 (permalink) Old 03-28-2009, 10:44 PM
Ultrafrozen's Avatar
These bearings are sealed on both sides and considered "sealed for life". This means the engineer who calculated the life of the bearing for this application figured it would outlast the normal life of the sled. This can save the manufacturer a whole lot of money on installing a grease nipple but causes the mechanic in all of us a little worry.
If you bother to take it apart to grease behind the seal, just replace the bearing instead. That way, you are sure the seal isn't damaged. Make sure you buy the same type of bearing with two seals or modify the flange housing to accept a grease nipple.
For your own peace of mind, change the bearing every five years or 5000 miles just to be sure. Modify the schedule as you see fit.
Ultrafrozen is offline
post #7 of 11 (permalink) Old 04-01-2009, 12:02 PM Thread Starter
Hoss98's Avatar
I was at the service shop the other day and he said the same thing, no lube needed, the bearing will outlast the sled. They could save money by not putting a decal on that says to grease a sealed bearing. LOL Thanks Guys
Hoss98 is offline
post #8 of 11 (permalink) Old 04-01-2009, 07:14 PM
Quoted: 101 Post(s)
AND keep us guys from worrying that we aren't maintaining our "babies" the way the manufacturer intended. Gawd.
BC_Dan is offline
post #9 of 11 (permalink) Old 10-31-2010, 08:19 AM
cyberlynx's Avatar
hey Dan i was searching jackshaft posts and i found this one, i think my jackshaft bearing is bad! the outsude race is turning in the aluminum holder or cassette i noticed the play when i was fooling with the belt, 3200 miles hopefully it all slides of easy
cyberlynx is offline
post #10 of 11 (permalink) Old 10-31-2010, 10:15 AM
If the outer race is spinning, the bearing is seized. Plan on changing it out. Check the track driveshaft bearings as well.
post #11 of 11 (permalink) Old 10-31-2010, 11:53 AM
Quoted: 101 Post(s)
What Ultra said. I hope you caught it before the damage was toooooo bad...
BC_Dan is offline
