1993 Polaris XCR 440 - Snowmobile Forum: Your #1 Snowmobile Forum
Old 03-08-2009, 06:32 AM   #1 (permalink)
2002 Yamaha SXViper 700
KoryM's Avatar
it is stock, and it wont katwalk now, what could i do to make it katwalk?
is there any well known problems with sled? or are there any things i should look out for?are they reliable? good on gas? oil hogs? good in powder? confortable? thanks alot for all your peoples help..
2002 Yamaha SXViper 700 Triple, Forced Air Induction, Y.P.V.S, 1 1/4" Ripsaw Track, Red Underglow, Renthal Bars w/6" Powermadd Riser w/Pivot adapter, Custom Windshield, Shock Covers, Starter Handle, Bilet Brake Lever, Fluid Cap, E-brake handle,
1999 Yamaha Phazer 500, ALL CUSTOMIZED - **SOLD**
1994 Yamaha Vmax 600, ALL STOCK - **SOLD**
_______________________________________________
Cant Piss on What Ya' Can't Chatch, Yamaha
11-12 kilometers:1200 kms
KoryM is offline   Reply With Quote
Old 03-08-2009, 11:08 AM   #2 (permalink)
Dbl R's Avatar
Clutch it, my brother in law had a 94 xlt with studded track. it was a dog, then we put a stiffer spring in it, would pull the skis off the ground for sixty feet. not to mention run a hundred in the snap of a fingure. it will cost you though replacing those belts more often.
Dbl R is offline   Reply With Quote
Old 03-08-2009, 03:13 PM   #3 (permalink)
KoryM's Avatar
what do you mean "clutch it"?
Old 03-08-2009, 03:41 PM   #4 (permalink)
Dbl R's Avatar
yeah bro just read up on some clutches How does the clutch system work? - Gates Snowmobile & ATV Belts
its good for you. the higher the rpm when the clutch engages the snappier it will be. You want to do katwalks dont you.
Old 03-08-2009, 03:58 PM   #5 (permalink)
KoryM's Avatar
my vmax i have now engages around 3000 and it wond do kat walks...is that because it is too heavy or it is engaging to low?...it is bad for the machine when it engages high? bad fuel mileage?
Old 03-08-2009, 04:00 PM   #6 (permalink)
KoryM's Avatar
how would i know if my clutches were bad? primary and secondary
Old 03-08-2009, 04:47 PM   #7 (permalink)
Dbl R's Avatar
You would have to pull them apart and check it out, theres rollers and weights that could have wear on them in the primary or the spring is weak etc etc.. There is a good post on here about cleaning and inspecting both of those clutches. Its a good idea to check and clean, however yes it will cause you problems if you make that thing katwalk. Cost you money and give you somthing too work on constantly
Old 03-08-2009, 04:53 PM   #8 (permalink)
Dbl R's Avatar
dont you watch you tube jump on the back as you punch it and pull that thing up... Have you tried that
Old 03-08-2009, 08:07 PM   #9 (permalink)
Polaris87's Avatar
All you need to do is....
Dalton Clutch kit with spring that engages at 6000 rpm
SLP pipes and can
240 Woody 1 1/4 studs
Weisco pistons and bore it .40 over
Port and polish it and plain the head .20
Sink about $4000 into it
In other words..Its a 440 XCR..Its not going to be super crazy. Sure there are things you can do to it...In some cases it might make you slower. A 600 XC is crazy fast but won't stand on end. Before you sink a bunch of money into it....ask your self if you like it that much that you wouldnt like to have a 600...or a 680 ultra SPX. I wouldnt worry about cat walking...Worry about off the line and top end. A clutch kit will make a diff but prob wont stand it on end.....My 600 XLT with .30 over pistons and a spring that lets it rev to 8500 full throttle wont stand on end by any means....Still works great though
540 Open Mod
1995 Polaris Indy 500
White EPI primary spring with 10 weights
Purple EPI secondary spring, 45/36 HRP helix
Polaris87 is offline   Reply With Quote
Old 03-09-2009, 01:10 PM   #10 (permalink)
If all you are interested in is pulling the skis off the snow, cut the limiting strap on the suspension. Will make it ride like crap, but the skis will come up. I had a Mach 1 that some one had done that to, looked impressive, but what a pile of junk.
Happy'sParts is offline   Reply With Quote
Old 07-31-2009, 09:48 AM   #11 (permalink)
KoryM's Avatar
thanks, but im going to spend all that money,,, thanks alot guys, im more interested in a 99 yamaha phazer now...
Old 07-31-2009, 10:27 PM   #12 (permalink)
big z's Avatar
if i were u, i would still look into a wedge style polaris, abundance of parts, highly modable. the phazer is not a bad choice though. except the ones older than 99'
current sled-04' polaris pro xr 440 factory race sled
big z is offline   Reply With Quote
Old 08-01-2009, 09:22 AM   #13 (permalink)
KoryM's Avatar
well, my dad has a pretty mean looking polaris, i should tell him to deck it out with lots of parts, and see what we can do...i just bought the phazer yesterday anyway,,, thanks with all your help
Old 08-01-2009, 09:42 AM   #14 (permalink)
big z's Avatar
cool! u should post pics
