After you rule out the belt and it still overheats, take a look at the water pump. Sometimes the nut that holds the impeller on comes loose, the pump will flow coolant at an idle, but as soon as the engine winds up, the shaft inside the impeller spins, and the impeller doesn't pump. Be careful, if it's the belt, you lose the oil pump too.. you can make it 4.5 miles on those big block Liberty engines before the lack of oil will seize the engine (been there).
