How to clean carbs? - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 22 (permalink) Old 07-14-2004, 03:00 AM Thread Starter
I Want a Rev
jimmyv13's Avatar
How to clean carbs?
I want to clean up my carbs and have been talking to different people about what I need to do. One guy says I need to disassemble everything and soak all the parts in degreaser, making sure they're clean and reassemble. That doesn't sound too bad....
Another guy that has been involved in racing sleds since the 50's, said all I need to do is simply place the carbs in a big pot of boiling water for a few minutes and that will break up all the crud. He said the Mikuni's don't have anything internally that will be harmed by the boiling technique, like rubber seals and whatnot, and I have nothing to worry about.
Hmmmm
I'd like to hear your guys preferred methods of carb cleaning. Thanks for helping out the newb
'02 MXZ 700 RER Renegade
'98 MXZ 440
'96 Z 440
jimmyv13 is offline
post #2 of 22 (permalink) Old 07-14-2004, 07:12 AM
not truckie or dak...Mike
I just put Gumout in my tank at the beginning of every season
daktruckie99 is offline
post #3 of 22 (permalink) Old 07-14-2004, 01:05 PM Thread Starter
I Want a Rev
jimmyv13's Avatar
I don't know if simply putting Gumout in the tank b4 I run will help my problem. I was fouling my middle plug after 100-150 miles towards the end of the season, so I know something is not working properly. The Gumout might work if the carbs aren't too bad, but I think my case is a bit more severe than most.
'98 MXZ 440
'96 Z 440
jimmyv13 is offline
post #4 of 22 (permalink) Old 07-14-2004, 01:15 PM
ohhh I didnt know you had a problem, thats a whole different story, I just thought you were keeping up with maintenance
post #5 of 22 (permalink) Old 07-14-2004, 01:56 PM Thread Starter
I Want a Rev
jimmyv13's Avatar
No worries....I will use the Gumout as precaution at the beginning of the season, I mean it can't hurt, right?
Thanks for the replies
jimmyv13 is offline
post #6 of 22 (permalink) Old 07-14-2004, 02:37 PM
nope it will definitely not hurt you, hehe
post #7 of 22 (permalink) Old 07-15-2004, 06:54 AM
If it's taking 100-150 miles to foul the plug, then your carbs are OK. A carb problem would be evident way sooner. Is the plug black and oily? I'd recommend trying one step hotter plug in that cylinder and see what happens.
2009 Ski Doo MXZ 500SS TnT
1999 Ski Doo MXZ600
smallengineguy is offline
post #8 of 22 (permalink) Old 07-15-2004, 12:10 PM Thread Starter
I Want a Rev
jimmyv13's Avatar
OK, I'll give that a try this season. I still run the stock temp plugs...I can't even remember whattemp they are??? 9's, maybe 8...??? I'll have to look....
I still want to get the carbs cleaned up, they have not been cleaned in 4 years, that I know of.
jimmyv13 is offline
post #9 of 22 (permalink) Old 07-15-2004, 05:28 PM
Go Wings!
skidoo_magoo's Avatar
yeah, its a good idea to clean em... well, i have heard of using degreaser. never anything about the boiling water but if there are no rubber parts or anything, it makes sense...
guess im not much help huh? id say both ways are good.
i know with my dirtbike, we put somethin in gasoline to clean it... my air filter or somethin??? i dunno.
i think ill use the gumout too on my rev... i wanna spoil that thing, since ill be on it!
skidoo_magoo is offline
post #10 of 22 (permalink) Old 07-15-2004, 07:18 PM
lol, I guess you dont know. As far as I know air filters filter out air not gasoline. hehe
post #11 of 22 (permalink) Old 07-15-2004, 08:02 PM
I still want to get the carbs cleaned up, they have not been cleaned in 4 years, that I know of. [/B][/QUOTE]
If you use the sled every year, there's no need to clean 'em. The only reason you should have to actually take them out and clean them is if it won't idle, pops and sputters, and generally runs like a jet is plugged. Other than that, don't mess with a good thing! I'd just do like above and run Gumout with your fuel.
1999 Ski Doo MXZ600
post #12 of 22 (permalink) Old 07-15-2004, 08:02 PM
Go Wings!
yeah, it filters ouit air, but to get all the crap out of it, we used gas... im probably wrong. what would you clean in gas???
post #13 of 22 (permalink) Old 07-15-2004, 09:17 PM
I get it now,I thought you meant you had put an additive in your fuel to clean out your air filter, lol
post #14 of 22 (permalink) Old 07-15-2004, 09:30 PM
Go Wings!
oh, i shoulda been more specific; we put it in a deep pan of gas and let it soak.
post #15 of 22 (permalink) Old 07-16-2004, 02:28 AM Thread Starter
I Want a Rev
jimmyv13's Avatar
If you use the sled every year, there's no need to clean 'em. The only reason you should have to actually take them out and clean them is if it won't idle, pops and sputters, and generally runs like a jet is plugged. Other than that, don't mess with a good thing! I'd just do like above and run Gumout with your fuel. [/B]
I don't know what running with a plugged jet is like. It idles OK, has a hard time starting once in a while, and loads up and fouls the center plug after a good run of 100-150 miles.
The sled was run very little, less than 200 miles in 4 years, before I bought it. I still want to clean them, I am very anal with anything I drive and I would rather not be left out on the trail because I skipped out on routine maintenance in the off season.
'98 MXZ 440
'96 Z 440
jimmyv13 is offline
post #16 of 22 (permalink) Old 07-16-2004, 06:40 AM
Remove the carbs, and then one at a time, disassemble and clean the jets, bowls, etc. I just use spray carb cleaner and compressed air. I wouldn't remove the inlet needles though. They are kinda hard to put back in, and since you don't have a problem getting fuel to the carb, that part is fine. most jets unscrew from the carb body. Just remember where your air bleed screws are set before you remove them (how many turns).
1999 Ski Doo MXZ600
post #17 of 22 (permalink) Old 08-25-2004, 12:43 PM
Quoted: 92 Post(s)
The biggest problem with plugged jets will be in the lean condition in the piston that the plugged jets cause. Lean is bad and expensive. Trust me. It does not take much dead gas turned to varnish in the float bowl to plug 'em.
A good cleaning of the carbs is easy and cheap maintenance and may prevent a melted piston.
I have used the aerosol carb cleaners to clean mine, it works fine. But I had heard about boiling the parts, so I tried that once after I had used the cleaner. I was amazed how much black crap came to the surface of the water from my "clean" carbs.
BC_Dan is offline
post #18 of 22 (permalink) Old 08-27-2004, 06:14 PM
Team HALFasst Racing
chase9119's Avatar
Ditto on what BC_Dan said, also take smallengine guy's advice. Do it one carb at a time, so you have a carb to referrence if you get out of control taking stuff apart. Also you may want to take out your air cleaner & tear that apart. If it was ridden so little in the past 4 years, you may have a nest or something restricting airflow.
Also a Polaris engine tech showed me a quick tip if your fouling plugs every 100 - 200 miles. (again this was a certified Polaris mechanic, so he has a butt load more knowledge then me.) When you open your air cleaner there will be a shelf right in the middle. It does almost NOTHING. Its just a big plastic plate with a couple of air holes drilled out. The main thing this shelf does it redirect any snow spray you may inject while DEEP powder riding. I say DEEP as in constant fluff coming over your hood. For trail riding & ditch banging you should be safe in removing this shelf. This also leans your machine a hair with out messing with your jeing. Polaris sent the tripples jetted VERY fat from the factory, so aside from rejetting, this technique suposably brings the motor back to life. (I noticed a slight mid-range & top end response with this mod.)
chase9119 is offline
post #19 of 22 (permalink) Old 12-08-2011, 04:21 PM
jdimi117's Avatar
Damaged Sled - where to begin??
I have a 1994 Polaris XCR 600 that hasn't been run very often over a period of about 6 years. I always had a hard time getting it started and it often did strange things like run with way high RPMs - even when just idling. So my friend who knew much more about sleds than I did decided to adjust the screws for the pilot air jets thinking the high RPMs were coming from a bad air to fuel ratio.
Shortly there after I accidentally rode it down to an empty tank of gas - and all that bad gas from the bottom of my tank probably went through the engine. Since it ran out of gas I have not been able to get the engine anywhere close to turning over.
What are the chances that I was running lean from messing with the carbs vs just a clot of sludge going in and mucking up the engine? Should I start by cleaning the carbs and what do I look for while doing it? What else should I do to undo years of sitting dormant? Sorry if some of this is repeat from other threads but ive looked everywhere and could use the straight answer. Thanks!
jdimi117 is offline
post #20 of 22 (permalink) Old 12-08-2011, 04:32 PM
Rick
indyryder500's Avatar
there is a how to thread on cleaning carbs that breaks it all down.
97 ultra spx slp can geared clutch and 144 studs.(mine)
96 XLT studded with reverse(12y/o son)
98 xcf 440 (wifes sled)
96 puma 340 elec start(kids sled)
96 cougar 550 2up bone stock (sold)
96 XCR 440 clutched (sold)
92 indy 500 bored,clutched. piped(sold)
85 indy 400 (11 y/o son's sled)(sold)
87 yamaha excel 340 (parting out)(sold)
2011/2012 miles :00000000
indyryder500 is offline
