polaris indy idling too high? - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 14 (permalink) Old 12-28-2008, 07:29 PM Thread Starter
X-tra L-ettuce & T-omato
polaris_olezy's Avatar
hey guys! well i got my last problem fixed and a new one arrised!
when i have let my sled idle it idles too high? like at the 4000 on the rpm gauge? it normally runs at 2000, but with a flick of the choke it idles back down to 2000, maby its a problem with the choke plunger? otherwise my sleds running good i just need to flick the choke every once in awhile when im idling it.
polaris_olezy is offline
post #2 of 14 (permalink) Old 12-28-2008, 07:31 PM Thread Starter
oh and i forgot my sleds a 93 polaris indy sks
post #3 of 14 (permalink) Old 12-28-2008, 07:49 PM
Tdiguy69's Avatar
Mines doing that some times to ill stop and it will hang at 4000 rpm....i was told that its usally a crank seal leak...so try spraying wd 40 around the block and if the rpm goes up your cranks leaking
1995 Polaris XCR 600
Plastic skis (purple)
Belly pan protector
Fox shocks all around
Heated grips and visor
Studded
Sportech headlight and tail light covers (purple)
Cobra windsheild (white with checkers)
Windsheild bag (purple)
Runing board trim (purple)
DG Silencer can
2 inch bar riser
Tdiguy69 is offline
post #4 of 14 (permalink) Old 12-28-2008, 07:56 PM Thread Starter
thanks tdiguy! ill giver a try one more question how much does a crank seal run for!?
post #5 of 14 (permalink) Old 12-28-2008, 07:58 PM
Tdiguy69's Avatar
Im not to sure how much it is for the seal...im guessing not alot but your going to have to pull the motor out to replace it thats the problem. Also check your carb boots i found mine are weather cracked and im replacing them and all fuel lines for cracks to.
Belly pan protector
Studded
DG Silencer can
2 inch bar riser
Tdiguy69 is offline
post #6 of 14 (permalink) Old 12-28-2008, 08:02 PM Thread Starter
i took my carbs out 2 nites ago thier fine, the previous owner said it did this and i didnt think anything of it? its running great still but it just wants to idle at 4k on the rpm meter haha, oh and it stopped doing this when i changed the plugs to champion and now that im back to NGK it just started?!
post #7 of 14 (permalink) Old 12-28-2008, 08:06 PM
Tdiguy69's Avatar
Weird mine started doing this also when i put new plugs in that were ngks also....what ones you put in 8s or 9s
Belly pan protector
Studded
DG Silencer can
2 inch bar riser
Tdiguy69 is offline
post #8 of 14 (permalink) Old 12-28-2008, 08:09 PM Thread Starter
i put 8's in the last owner had 9's and he was fouling them by the dozen!
post #9 of 14 (permalink) Old 12-28-2008, 08:13 PM
Tdiguy69's Avatar
mine had 8s. If you want good plugs try BR9EYA or 8s there designed to not foul as easy.
Belly pan protector
Studded
DG Silencer can
2 inch bar riser
Tdiguy69 is offline
post #10 of 14 (permalink) Old 12-28-2008, 08:15 PM Thread Starter
well than thier doing the trick haha, these plugs are damn good! the champions i had gave me some trouble after the first day i had them, they were all black and nasty looking!
post #11 of 14 (permalink) Old 12-28-2008, 08:18 PM
Tdiguy69's Avatar
Okay if you have more problems check your plug caps to. I just had a spark plug cap go bad i hit a drift and snow came in through the screen and made the sled run on 2 cyclinders. I added some dielectric grease to all my caps to increase water resistance.
Belly pan protector
Studded
DG Silencer can
2 inch bar riser
Tdiguy69 is offline
post #12 of 14 (permalink) Old 12-28-2008, 08:20 PM Thread Starter
ok thanks tdiguy, needed the help haha!
post #13 of 14 (permalink) Old 12-28-2008, 08:21 PM
Tdiguy69's Avatar
Best of luck....let me know if your cranks leaking.
Belly pan protector
Studded
DG Silencer can
2 inch bar riser
Tdiguy69 is offline
post #14 of 14 (permalink) Old 12-28-2008, 08:27 PM Thread Starter
ill need it! but i will remember to get back to you about the crank seal im not near my sled rite now but i will be in a bit, thanks alot man!!!!!
