Cant Get My Sled To Fire Up - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 9 (permalink) Old 12-01-2008, 12:09 AM Thread Starter
whats a wench for????
I Have A 92 Polaris Indy Trail..bought It For $100....i Cant Get Gas Up To The Carbs...
I Replaced All The Fuel Lines On The Sled And In The Gas Tank Too.i Added A Inline Fuel Filter Before The Shut Of Valve.....one Line Was Cut Off The Fuel Pump And A Guy Told Me It Should Go To The Engine Block Because It Runs Off Vacum/pulse Off The Motor...i Pull The Choke And It Wont Fire...i Sprayed Some Starter Fluid In Each Carbs And Add A Lil Oil In Each Cylinder.before I Started It .(someone Said Starter Fluid Is A Big No No For Sleds..i Did It Just To See If The Motor Would Sputter Up Enuff To Get The Pump Movin. Motor Sputtered And Died... I Wont Be Doing That Again.)i Think Maybe It Might Be The Feul Pump..also I Found That There Are 2 Hoses That Are Pluged Off Under Each Carb(1 Hose Per Carb) Should They Be Pluged?..how Can I Check The Fuel Pump? Can I Rebuild It?
I Also Have Electric Started If That Helps.
I Dont Know Much About Sleds Except Thy Look Fun To Play With ...
Thanks For All The Previous Help ..the Site Rules Because Of You Guys...
Thanx
Snax
snax is offline
post #2 of 9 (permalink) Old 12-01-2008, 12:19 AM
highmark600's Avatar
I'd check to see if the spark plugs are sparking. Sounds like a bad fuel pump. The hoses underneath the carbs should be plugged, and well sealed. They are there to catch any extra/unused gas, which eventually gets burned.
1999 Ski-Doo Summit 600
1990 Polaris Indy 500
1973 TNT-Restoration Project
1967 Land Rover 88 Series IIA-for haulin'
highmark600 is offline
post #3 of 9 (permalink) Old 12-01-2008, 01:39 AM Thread Starter
I Am Getting Spark.. I Sprayed Starter Fluid In It And It Ran For A Second. I Checked It Before I Realy Tried To Fire It Up......thats Why I Think Its The Fuel Pump......how Do I Check/know If The Fuel Pump Is Bad?
snax is offline
post #4 of 9 (permalink) Old 12-01-2008, 07:13 AM
Yes, there should be a line that goes from the fuel pump to the engine block. Is the line still cut off, or did you replace it? The fuel pump will not work without it.
L.T. Grey is offline
post #5 of 9 (permalink) Old 12-01-2008, 05:31 PM Thread Starter
I REPLACED IT ..ONE OF THE GUYS IN THE SHOP SAID ALL LINES NEED TO BE TIGHT SO THERE IS NO AIR IN THE SYSTEM AND I NEED TO JUST PUT SOME GAS IN A SQUEEZ BOTTLE AND SPRAY THE CARB TO SEE IF THE MOTOR WILL PRIME THE PUMP...HE SAID IT TAKES A WHILE TO PRIME A FUEL PUMP....
THANX FOR THE HELP..
snax
snax is offline
post #6 of 9 (permalink) Old 12-01-2008, 05:42 PM
dan151's Avatar
yeah and if you decide to replace the fuel pump, most dealers can order a new Mikuni fuel pump which is much cheaper then replacing OEM ones, i just ordered one and it saved me 40 bucks.
dan151 is offline
post #7 of 9 (permalink) Old 12-01-2008, 10:24 PM
jcurrieta
i know i sounds dumb but are all your lines good still.... also is there fuel in the tank if all the gas leaked out some how you may be empty....just a thought a shot in the dark maybe but you should check it if you didnt.
cause if you pull of the line to the carb and pull it a few times you should see gas comeing out.
'06 Yamaha Apex RTX
'03 Yamaha RX1 "sold"
'98 Arctic Cat 600 ZR "sold"
'03 Ski-doo 600 MXZ REV "sold"
'91 Polaris Indy 500 "sold"
jcurrieta is offline
post #8 of 9 (permalink) Old 12-01-2008, 10:56 PM Thread Starter
I Got It To Fire ...i Just Put Some Gas In The Bowls To Help Prime It And She Fired Up...i Have To Give It A Lil Throttle So It Stays Runnin...and I Have To Get A New/used Choke Cable Mine Is Missing The Handle..bumed....is There Supost To Be Oil Coming Out Of The Exhaust Under The Sled? And I Decided I Should Be Good To Rebuild The Carbs After It Fired Up....i Took Them Apart And Was Missing The Ends Of The Chokes/or Some Pieces Because They Were Not Atached To Any Thing..on Had A Spring In It And The Other One Didnt.
I Was Lookin At One Of The Stickie Forums And Mine Did Not Have The Blk Thing On Them I Think It Was Called A Choke Plunger
snax is offline
post #9 of 9 (permalink) Old 12-02-2008, 08:53 AM
TRH- Troll Raising Hell
SMFXRSB's Avatar
Is That A Pain In The Ass To Always Type Like This? It was for me...
Snow: The other white drug!
SMFXRSB is offline
