Old 10-06-2008, 08:24 AM   #1 (permalink)
Evilice
Evilice's Avatar
2004 700 XCSP EDGE Suspension removal
I want to remove my suspension but I seem to need a special wrench to hold on to the back side of the bolts that are holding the suspension in at the very rear of my tunnel. It looks like I need a very thin wrench to grab onto them. It looks like its a 7/8 wrench that needs to be milled down to a certain thickness. Can anyone confirm this size?
Evilice is offline   Reply With Quote
Old 10-07-2008, 07:35 AM   #2 (permalink)
Can you air wrench it?
Old 10-07-2008, 10:42 AM   #3 (permalink)
Evilice
Evilice's Avatar
Nope
No, but I took a 7/8 wrench to work and milled it down. Have not tried it yet.
Old 10-07-2008, 05:57 PM   #4 (permalink)
Octane
Amateur Lumberjack
Octane's Avatar
You can buy open-end wrenchs that are slim.
'01 Polaris Indy 600 XC SP EDGE X
Powermadd articulating bar riser with 2" riser block (total rise of 4 1/2")
Pro-X seat
red Cobra low sno-x windshield
Pure Polaris handguards with Pure Polaris mounts
almond/blue drive clutch spring with 10-60 weights
121" x 15" x .91" track with 96 studs.
7,100 miles
Octane is offline   Reply With Quote
Old 10-08-2008, 01:53 PM   #5 (permalink)
03XCSP500
THE DUDE ON THE POLARIS
03XCSP500's Avatar
yeah i had the same problem. they are 7/8" or even 1". i cant remember. i does have to be a thin wrench.
03 XC SP 500
V-Force Reeds, 144 Woody's Studs, SLP Rumble Pack, Camoplast Track, Dual K&N Air Filters
03XCSP500 is offline   Reply With Quote
Old 10-08-2008, 09:32 PM   #6 (permalink)
BC_Dan
Sometimes you can loosen one side with an air wrench, then retighten it, then loosen the other side with an air wrench and then go back to the first side to completely remove. Often, they are a bugger. Grinding down a cheap wrench and having it in your toolbox is an inexpensive addition to the toolbox...
Rebuilding the fleet!
Old 10-08-2008, 10:08 PM   #7 (permalink)
Octane
Amateur Lumberjack
Octane's Avatar
The only problem is that the heat of griding it will remove the temper and weaken the wrench.
Buying a slimline wrench is a better option because its molded to be thin and you wont remove the temper with the heat of grinding it.
Pro-X seat
7,100 miles
Old 10-09-2008, 07:10 PM   #8 (permalink)
JheLrey
JheLrey's Avatar
If you have a variety of tools with wrenches included for changing a blade,etc... try one of those.
