Changed pistons, 1st overbore, what else?
2000 Polaris Triumph, 600cc triple (XLT engine?).
My first piston went bad at 2,600miles, so I am re-building the whole engine. Bored out the block, and replaced pistons with 1st oversize 010. I've heard that I now have to do something with the mixture ratio. Replacing jets? Re-adjusting stuff?
I also re-built the gas diaphragm, and replaced oil seals. This is my first sled, and I don't know much about them. Is there anything else that should be done?
Before the first piston burned down. I could hardly start the sled, and it smoked a lot, but the compression was around 120psi. I cleaned the carbs, but didn't replace anything in them.
My questions:
*Adjusting/replacing parts due to piston oversize?
*Oil pump tuning/replacing?
*Anything else anyone would recommend?
