Old 07-19-2008, 09:33 PM   #1 (permalink)
lrnnorth
Above The Arctic Circle
lrnnorth's Avatar
Exhaust Valve Q
When i took my valves off to clean them the pto side valve was hardly carboned up and the mag side was really bad. I was expecting them to be quite dirty because i never cleaned them for a while but im suprised as to why the one wasnt dirty. Does anyone know what would make this happen?
01 Polaris RMK 136"
- 01 600 VES Engine - Uni Air Filters
- Sno Stuff Rumble Pack - Powermadd Boost Bottle
- Custom Painted Hood - Powermadd Bar Riser
- EPI Pro Series Clutch Kit - Xtra-10 rear suspension
01 Yamaha VK III 540 (The TANK)
Out Of Commission Till Next Year
lrnnorth is offline   Reply With Quote
Old 07-20-2008, 10:38 AM   #2 (permalink)
BC_Dan
How is the piston wash/plug color side to side? If the PTO side is running a bit leaner (hotter) it won't build up carbon as much. How is the compression?
Old 07-20-2008, 11:46 PM   #3 (permalink)
lrnnorth
lrnnorth's Avatar
The motor hasnt run for a couple of months and it is out of my sled but i always check the jetting on it when i drive. I was missing a bolt for my y-pipe on that side so i am thinking that is the reason. I did a compression test on it in Dec and both sides were a little above 130 psi.
01 Polaris RMK 136"
Old 07-22-2008, 07:46 AM   #4 (permalink)
One side is a little richer than the other. Nothing to worry about at least.
