05-13-2008, 03:04 PM
'00 Polaris Indy 500
help: indy 500 handlebars
i have a 2000 indy 500 and i am wondering if its possible to put handlebar risers on it. would you have to remove the plastic covering to do that? how high could you go without needing throttle/brake extension? attach pictures if you have any.
The older the better!!
1980 Enticer 300
2000 Indy 500
Warwick Snowmobile Club
05-16-2008, 10:33 AM
GO GREEN OR GO HOME!
you could probably 3 inches def 2.
2003 ARCTIC CAT ZL 600 EFI SS-2700 MILES-GETTING SOME MILD TWEAKING THIS SUMMER
2002 ARCTIC CAT Z 440 ES-622 MILES-MINT, JUST LOOKING FOR SOME STUDS AND FATBOY TORSIONS.
1997 ARCTIC CAT EXT 580 EFI DLX 4000 MILES- SOLD 8/08
1998 ARCTIC CAT ZR 600 EFI-3700 MILES-BUILT- SOLD-9/07
1996 INDY CLASSIC 500 ESR-5100 MILES- SOLD 4/08
1987 SKI DOO FORMULA MX 470-12000 MILES- SOLD 12/07
09-06-2008, 03:53 PM
bar riser alternative
I have the perfect solution for you...okay here is a low cost alternative to buying a new bar riser kit. what i did was take some left over oak baseboard and cut them all the same length, about 3-1/2'' you may want a solid chunk of oak blocking,and drill the holes through. here are some pics of my sled, and i have used this setup for over a year, with no problems. you also have to buy some threaded rod, because i couldnt find bolts long enough. My wife also made this 'scarf' to cover the gap between the sled and the bars!! it made a world of difference, this 3'' bar rise was amazing... cost: about $4.00
09-06-2008, 04:42 PM
09-06-2008, 11:10 PM
That is a redneck way of doing it! Haha!
09-07-2008, 09:09 PM
did you have to extend the throttle or brake cables with 3 inches? how tight are the cables?
1980 Enticer 300
2000 Indy 500
09-08-2008, 10:47 AM
redneck bar riser
redneck yes, but it cost only $4.00 and works just as well. And to respond to Freersy, no i did not have to extend the throttle and brake, they work perfect, as is... so the answer to your question is you can put a 3'' riser on your sled with no worries about throttle or brake line extensions.
09-08-2008, 10:51 AM
Any problems with termites??
09-08-2008, 11:01 AM
no, no termites, well, not that i see, but this year i may just go and buy a proper riser for it, because i might be buying an '01 rmk 800, so i might as well do both
09-08-2008, 04:58 PM
does anyone know if the cables are different lengths on the 500 xcsp, compared to the indy 500. i'm just making sure, its hard to return where i'm buying from
1980 Enticer 300
2000 Indy 500
09-09-2008, 11:42 AM
Im pretty sure they are exactly the same, as they have the exact body style, same hood, same bars, im sure they are the same
09-10-2008, 10:31 AM
I also have a 2000 Indy 500 XC, I put a 3" riser on it a couple seasons ago,then to cover the gap, I took a piece of 4" plastic drain tile,cut it down the center, wrapped it around the base of the steering cover, and cut to fit the gap,then put a couple screws in it to hold it together. It almost looks factory, has held up for 2 years so far, and the 3" is perfect lift for most trail/ditch riding, and no mods to the cables was needed.
2000 Indy 500 XC, Fox shocks up front, M10 trail in back. '99 440 XCR for my son.
09-10-2008, 06:26 PM
stimpy, do u got any pictures?
1980 Enticer 300
2000 Indy 500
09-11-2008, 06:43 AM
I'll see if I can get you one posted in the next day or two.
