This has been an ongoing problem....
It appears that the stop light pressure switch was leaking. We bled the brakes again last night.
If you ever have leaves in the bottom of the belly pan right next to your exhaust pipes, clean them out before you go for a test ride.....
Can any of you guys tell me what the female bullet connectors are called that plug onto this switch? The Polaris shop wants $80.00 -
no way!
http://www.speedwaymotors.com/Pressu...-NPT,1971.html
....also, does anyone have a recommendation for on-board fire extinguishers?
